timing control
timing control
whats everybody using for timing control? looking for info on something on the fly adjustable and from the guys using controllers to have and ignition set up that will mach ur nitrous ramp or just pull the timing at the begging of the run and let it go
bigben- Posts : 52
Re: timing control
Any msd digital ignition pretty much. Most use either the grid or 7531. We use the fuel injection to do all that but we primarily do cnp ignition setups.
whatbumper- Posts : 3024
Re: timing control
on the sb car I have a plate and just a single stage retard box, we run the base low ( just has to do a burnout and come up on the brake) and yank it all at the hit...... works good.
The bb car I use a msd 8 plus box that a 7531 controls, i pull for each stage and ramp the timing out....... i pull a good bit on both kits and yanking it all at once really knocks the wind out of the sails.
a 7531 is pretty easy to find used as most are using grids now.
Re: timing control
Well unless things change my plate only goes to 250 I'd like to run a controller just so I don't blow tires off on hit so that's why I'm wondering how to retard the timing best on the cheap if I can
bigben- Posts : 52
Re: timing control
Progressive controller work great and are easy to use. The ignition boxes can offer some control but many find it more complicated.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
» Advance Cam or Not ?
» Timing Pointer for Stock Timing Cover
» engine timing and nitrous timing
» Gun Control
» Home invasion spoiled
» Gun Control
