To big of carb?
To big of carb?
I have a 78 f100
4000pds
466cid
C6 trans
stealth intake dual plane
Duration @ .050" Lift 240/246 584int 588ex
10.5 compression aluminum Eddy heads
3000-3500 stall converter
4.11 9'' rear 29'' tire 2WD
My question is im looking in to getting a new carb QF 850DP with Annular Boosters very expensive for a guy like me what I have now is a 750VAC holley the truck will see a lot of street time will one have trouble with a carb this big and a truck this heavy
4000pds
466cid
C6 trans
Rabbit- Posts : 57
Re: To big of carb?
It will run better with the 850, but I'm not sure it would be worth the extra expense.
If your exhaust isn't up to the task ( headers 3 inch with flow through muffles) the 850 may not be much improvement.
Re: To big of carb?
headers 1 3/4 to 3'' pipes glasspacks
Rabbit- Posts : 57
Re: To big of carb?
I would probably borrow a good 850 from a buddy to see if it picks up, before I bought one. I'm thinking with 1 3/4 primary's it wont show you much.
» weiand carb adapter 4500 carb flange to 4150 intake
» Gas carb v/s Alky carb
» Problem with car racing
» GAS TO E-85 carb
» Getting a carb
» GAS TO E-85 carb
» Getting a carb
