638 C460 Headed BBF
+24
68galaxie
yellowhorse7
old blue
psfracer
Snowball Racing
rocketpony
STR-LGL-70
nuclearcobra
kjett
QtrWarrior
28 posters
Page 2 of 5
Page 2 of 5 • 1, 2, 3, 4, 5
Re: 638 C460 Headed BBF
wowzers....that's some flow.
windsor- Posts : 1167
Nice build Davey ole boy, that should quality you as a jet pilot.
Was that with a 2.45 intake valve? Also what bore fixture dia.?
Thanks, Sheldon
Thanks, Sheldon
STR-LGL-70- Posts : 223
Yes, 2.45 Manley Ti intakes. Not sure what fixture. These are my old C heads.
schmitty- Posts : 4538
Yes 4.625 bore
Pistons are in !
That Big Dog is gonna be Hungry, finish er up and let er Eat
FalconEh- Posts : 1448
schmitty wrote:Yes, 2.45 Manley Ti intakes. Not sure what fixture. These are my old C heads.
Would these work on a 4.500" bore?
68formalGT- Posts : 865
There would be a problem with valve shrouding at that bore.
schmitty wrote:There would be a problem with valve shrouding at that bore.
What is the minimum suggested bore for the 2.45" valve C heads, 4.600"?
68formalGT wrote:schmitty wrote:There would be a problem with valve shrouding at that bore.
4.600 is recommended but they will function in smaller bores.
Does the crank have a standard snout or a Boss snout?
dfree383 wrote:Boss
So they come standard or just boss?
68formalGT wrote:dfree383 wrote:Boss
I'm not sure I never asked. I knew I wanted the boss about when the build started.
rocketpony wrote:Any update on this?
All the parts are sitting there, got other things in front of it right now. My 5.0 stock eliminator and another run at the engine masters.
Bump.........because it's been a while
send that bitch down here, we will put it in the rolling dyno
Snowball Racing- Posts : 85
Snowball Racing wrote:send that bitch down here, we will put it in the rolling dyno
We have 4 of them. Pick a color. Purple, Blue, Red and Black lol
BigBlockFalcon wrote:Snowball Racing wrote:send that bitch down here, we will put it in the rolling dyno
Got me a 2008 blue rolling dyno now.
dfree383 wrote:Got me a 2008 blue rolling dyno now.
Got doors?
jbozzelle- Posts : 3705
jbozzelle wrote:dfree383 wrote:Got me a 2008 blue rolling dyno now.
Got doors?
Yep
Any numbers on this one? Just curious as my heads have a very similar peak flow. Obviously its more than just peak flow numbers that make a build, but just curious regardless.
» New C460 Intake Manifold M-9424-C460
» c460 pistons
» c460 cam.
» IF YOU LOOKING FOR C460 CAM
» Timing For C460 604 CID
» c460 pistons
» c460 cam.
Page 2 of 5
