638 C460 Headed BBF
+24
68galaxie
yellowhorse7
old blue
psfracer
Snowball Racing
rocketpony
STR-LGL-70
nuclearcobra
kjett
QtrWarrior
28 posters
Page 4 of 5
Page 4 of 5 • 1, 2, 3, 4, 5
Re: 638 C460 Headed BBF
dfree383 wrote:rmcomprandy wrote:dfree383 wrote:rmcomprandy wrote:WoW ...
2 1/2 years and 3 pages of posts in the "Proven Builds" section about an engine which hasn't even been run yet.
Previous shop 2.5 years+ no progress..... current shop 4 months and ready to dyno...... imagine that.
Just pointing out that this is "Proven Builds" not "Projected Builds". To some people there must be no difference.
The proof is on the way
I imagine some pretty impressive proof numbers at that!!!!
old blue- Posts : 124
It's on the pump
Awesome!
68formalGT- Posts : 865
Short warm up pull 1140 at 6800, no tuning
Oh my...
windsor- Posts : 1167
Awesome start
On C-16
Are you going to try a Q-16 pull?
68formalGT wrote:Are you going to try a Q-16 pull?
Probably not, I don't intend to run it
what did it make on a hot pull tuned
69F100 wrote:what did it make on a hot pull tuned
Ran out of time this week and bob is working the weekend, won't do anymore pulls till next weekend
dfree383 wrote:68formalGT wrote:Are you going to try a Q-16 pull?
Are you planning on spraying it?
68formalGT wrote:dfree383 wrote:68formalGT wrote:Are you going to try a Q-16 pull?
No
What carb/size did you end up going with?
Pretty impressive starting number, looking forward to next update
Ended up with 1100hp at 6800 and 920 to at 5800
On C16 with a quick fuel 1450 with a out of the box intake port matched only.
It's on a tight Stuska dyno too, not a superflo like most everybody uses.
Damn, get that beast in a car so we can see what she runs!!!!
Should certainly haul the mail. Sweet build.
I am sure there is a bit left on the table with the OTB (port matched) single four intake manifold.
Did you flow test the head with the intake in place?
More pics?
Cheers!!
More pics?
Cheers!!
68galaxie- Posts : 351
No we didn't flow with the intake. Just clay radius in the intake with a 4.625 bore.
I want to upgrade to EFI in the future, the C460 cast manifolds have some very poor distribution
Too bad BBF cast manifold choices are limited to one (C460). BBC guys have many many choices these days.
A Sniper BBF would be nice for C460.
You didn't pull it higher than 6800 or that was where it made peak or...?
Kind sounds like what Ford use to do ! IE : 428 CJ rated at 335 HP , ya @ 4000 rpm !! LOL
Frank Merkl- Posts : 1524
68galaxie wrote:Too bad BBF cast manifold choices are limited to one (C460). BBC guys have many many choices these days.
You could use the adapter plates and use A460 intakes. That new Eliminator intake would look good on there.
Frank Merkl wrote:Kind sounds like what Ford use to do ! IE : 428 CJ rated at 335 HP , ya @ 4000 rpm !! LOL
Nobody sand bags anymore Frank
John Myrick- BBF CONTRIBUTOR
Shhhhhhhh........
» New C460 Intake Manifold M-9424-C460
» c460 pistons
» c460 cam.
» IF YOU LOOKING FOR C460 CAM
» Timing For C460 604 CID
» c460 pistons
» c460 cam.
Page 4 of 5
