521" pump gas engine
+17
460bronco
nuclearcobra
68galaxie
quick 52
514F-1
jones
droppedf100
whitefield
Fla Fairlane
jeffgfg
61coon
gmsmkr
21 posters
521" pump gas engine  Empty 521" pump gas engine
Post  Lem Evans November 26th 2014, 8:08 pm
521" pump gas engine  CCI11252014_00000Large_zps197b70ba
Solid flat tappet cam.
521" pump gas engine  Empty Re: 521" pump gas engine
Post  gmsmkr November 26th 2014, 9:50 pm
Good numbers Cool sensor not working right on the left side
gmsmkr
gmsmkr
Post  Lem Evans November 26th 2014, 10:00 pm
gmsmkr wrote:Good numbers Cool  sensor not working right on the left side
Cheap headers did not have a bung....the sensor was in the after pipeing which was blown of during the pull.
Post  FalconEh November 26th 2014, 10:47 pm
Nice Cool Why is the oil pressure dropping at peak
Post  61coon November 27th 2014, 10:07 am
Nice build and good numbers Lem. That'll be a fun deal. What's it going in?
61coon
61coon
Post  jeffgfg November 27th 2014, 10:42 am
Nice Lem..Can you share the specs or are they secret?? Nice torque numbers across the board!!!
jeffgfg
Post  Lem Evans November 27th 2014, 11:40 am
61coon wrote:Nice build and good numbers Lem. That'll be a fun deal. What's it going in?
60s Fairlane.
Post  Lem Evans November 27th 2014, 1:24 pm
jeffgfg wrote:Nice Lem..Can you share the specs or are they secret?? Nice torque numbers across the board!!!
There is nothing magic or fancy here.
Lunati crank, scat rods, probe pistons and a D1VE block.
SCJA heads, o.t.b. tfs 'mafia' manifold, jomar power cone spacer and a qfx 1050 carb.
Comp cam, lifters, rocker arms and trend pushrods.
Post  Fla Fairlane November 30th 2014, 6:56 pm
A big thank you goes out to Lem and Phillip Oakley with the build. My original idea was to use a torker II and aim for the 650ish Hp mark. After the hood clearance was doubled checked and seeing the port work required to get the torker II to work we decided to give the mafia intake a go. It ended up being much more than I expected and definitely more power than the car can put to the ground. It will be going in a 67 fairlane sedan backed with a c-6 and probably 3500ish converter. Not a race car by any means just a weekend play toy, street terror, tire roaster Very Happy
Fla Fairlane
Post  bbf-falcon December 1st 2014, 6:47 pm
Fla Fairlane wrote:A big thank you goes out to Lem and Phillip Oakley with the build. My original idea was to use a torker II and aim for the 650ish Hp mark. After the hood clearance was doubled checked and seeing the port work required to get the torker II to work we decided to give the mafia intake a go. It ended up being much more than I expected and definitely more power than the car can put to the ground. It will be going in a 67 fairlane sedan backed with a c-6 and probably 3500ish converter. Not a race car by any means just a weekend play toy, street terror, tire roaster Very Happy
Cool beans Wink Very Happy
Post  whitefield December 1st 2014, 7:35 pm
Nice build Very Happy what is the compression. .?
whitefield
whitefield
Post  Lem Evans December 1st 2014, 7:40 pm
10.6:1
Post  whitefield December 1st 2014, 7:42 pm
That be up tight out of sight in my 64 afro
whitefield
whitefield
Post  droppedf100 December 17th 2014, 1:24 pm
That is badass with pump gas and a solid flat tappet. Where is the limit in a flat tappet? Could a cam be grinded to make good power with a460 heads?
droppedf100
droppedf100
Post  jones December 17th 2014, 1:36 pm
Cool,, thanks for bringing this back up to the top!
jones
Post  dfree383 December 17th 2014, 2:50 pm
jones wrote:Cool,, thanks for bringing this back up to the top!
These are just internet BS numbers, done for magazines on inflated dynos..... lol!
Post  jones December 17th 2014, 3:22 pm
pale Cool
jones
Post  dfree383 December 17th 2014, 8:14 pm
pale Cool
That's a joke Jones! Those numbers are off a reasonable dyno, built by people in the know.
Post  514F-1 December 17th 2014, 8:23 pm
Nice build, fairly low HP Per dollar as well I'm sure. Question, how do you guys running flat tappets keep from wiping lobes off of cams, I run solid rollers in mine, but I have heard of the probs. with the flat tappet cams. Also, was the cam Hyd or solid?? Fla Fairlane, where in FL are you from?? Again, nice build...
514F-1
514F-1
Post  Lem Evans December 17th 2014, 9:17 pm
514F-1 wrote:Nice build, fairly low HP Per dollar as well I'm sure. Question, how do you guys running flat tappets keep from wiping lobes off of cams, I run solid rollers in mine, but I have heard of the probs. with the flat tappet cams. Also, was the cam Hyd or solid?? Fla Fairlane, where in FL are you from?? Again, nice build...
It's a solid flat tappet deal. As far as "wiping lobes"....it is seldom the cam or lifter's fault.
Post  quick 52 December 18th 2014, 9:29 am
Cool truck I have a 51 f1.. Can you show your rollbar setup
quick 52
Post  68galaxie December 18th 2014, 6:18 pm
Oh, I see you forgot that this build has ported SCJ heads, mafia intake, 10.6:1 compression (measured), and a custom cam I am thinking.  This is not a typical mass assembled Ford Motorsports crate 521. The engine assembly was very carefully assembled,
low tension rings? maybe, and many other details that lead to better than average power output.
And yes, many internet and magazine published HP figures are B.S. I would have thought you were smarter than this.
68galaxie
68galaxie
Post  droppedf100 December 18th 2014, 7:13 pm
I'd like to know the power/reliability limit with a solid ft cam. Would a flat tappet be able to make good power with A heads?
droppedf100
droppedf100
Post  Lem Evans December 18th 2014, 8:17 pm
droppedf100 wrote:I'd like to know the power/reliability limit with a solid ft cam. Would a flat tappet be able to make good power with A heads?
The issue...i.m.o. with a s.f.t. cam in an A460 package would be the limited lift that would be available in a typical affordable s.f.t. cam.
The FRPP SCJ head's flow curve is a natural fit for a typical s.f.t cam....... .600" - .650" lift.
Post  dfree383 December 18th 2014, 11:45 pm
Really? Please school me, do you dyno engines often?
