what years are interchangeable for pedals?
what years are interchangeable for pedals?  Empty what years are interchangeable for pedals?
Post  Bart Knox January 27th 2015, 5:32 pm
I have pedals from a 90 f150 will they work with 95 bronco?
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
what years are interchangeable for pedals?  Empty Re: what years are interchangeable for pedals?
Post  HorsinAround February 2nd 2015, 3:06 pm
No, I don't believe they will work.
http://www.frontpagefab.com
Post  schmitty February 2nd 2015, 4:37 pm
I think that they would work. Those years cabs were the same.
Post  HorsinAround February 2nd 2015, 4:59 pm
The cabs are ALMOST the same. The mounting for the pedals is different.
Take a look at the pictures in the link below. You can see that the mounting plate is different after 91. Also if you look closely, it does appear that the spacers for the brake pedal are different after 91. Now, If you are only looking at the pedals, you could make spacers to adapt, but if you are looking at the entire assembly, they are different and will not interchange without modifications.
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=38
Post  schmitty February 2nd 2015, 5:09 pm
I see, 92 and up would work.
Post  Bart Knox February 3rd 2015, 2:35 pm
Thanks for the help got everything just I need but expect clutch linkage I got the pedals from 95 f150 can iI use the master from that truck work with the slave and line that came with the 460 bellhousing I think the 95 was internal slave
Bart Knox
Bart Knox
what years are interchangeable for pedals?  Empty 150 or 250 master
Post  Bart Knox February 4th 2015, 8:58 pm
I am thinking I'll get new master should I be getting the 302 master or 95 f250 460 master the slave and line came with 460 bellhousing
Bart Knox
Bart Knox
Post  HorsinAround February 5th 2015, 12:26 pm
If you are not upgrading the axles and calipers, then I think you would want to use one for a 302 if that is what was in it.
Post  Bart Knox February 5th 2015, 1:38 pm
302 master will hook up to the bigger slave? the slaves were not the same part number I found anuther 95 150 with master line and external slave just don't know what will hook together or if the external slave from 150 will hook to 460 bellhousing
Bart Knox
Bart Knox
Post  HorsinAround February 5th 2015, 1:47 pm
Sorry, I was thinking of the brakes. for a clutch, yes get one for the F250/460.
Post  Bart Knox February 5th 2015, 3:35 pm
Thanks a lot for the info -30 C here but I'm getting it done let yous know when I get it going if I don't run into any more problems I'll try to load a picture I couldn't figure out how before just finished a 4 inch body lift sitting about 12 13 inch now looks ok with new boggers thanks again
Bart Knox
Bart Knox
