C6 Tranny yoke turns hard in neutral
What would cause my yoke to be really stiff in neutral on my C6?
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: C6 Tranny yoke turns hard in neutral
Tore wrote:What would cause my yoke to be really stiff in neutral on my C6?
Thanks Tore
Clutch pack clearance or stack up wrong ! Is it stiff to turn in one direction and not the other ?
Is there anything wrong with the trans other than stiff to turn in neutral ?
whitefield- Posts : 2244
Be honest with you I only have turned it in one direction and I have no idea if the tranny is bad I bought it used and it supposedly ran good in his car.
Tore
Tore
Tore- Posts : 865
How "stiff" is "stiff"?
crittersf1- Posts : 521
Like Critter says how stiff is stiff?Whenever you turn it regardless of direction one hand should turn it over easily enough .If you need two hands on that yoke maybe it is to tight .The end play might be setup tight .The spec in my book says .008-.044 so it could be on the tight side normally my trans are in the .020s .And this trans of yours probably doesn't have any roller mods.Somehow I imagine your transmission is alright .Although if this is going into a race vehicle I might pull it down for a check out .And you could check the endplay to see if it was in spec.Doug
manofmerc- BBF CONTRIBUTOR
I put a yoke in another tranny and turned it over and it does take more effort to turn the one in the race car. Not a lot more but it is noticeable.
I am going to run it and see what happens.
Thanks for the replies guys.
Tore
Tore
Tore- Posts : 865
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Car barely budges in neutral?
» Who makes a stub distributor (need it it turns oil pump only) F.I. Motor
» Colorado man turns in a Maserati BiTurbo for the Cash for Clunkers
» C6 Clean neutral VB
