521 Pump Gas build "Honey Bunny"
+6
cheatham
Gregaust
jones
10 posters
I have to thank Lem Evans, Phillip Oakley and Jet Boat Bob for building this engine for me. I called Lem and told him I want a pump gas engine for my four wheel drive truck that uses a solid roller camshaft and won't tear it's self to pieces driving to events on the weekends. I also added I'd like to have enough power to act a fool when I want too and have a exhaust note that would send chills thru women and small children.
This is a brief run down, I'm sure I have something wrong and will update as I get more information.
Parts by Lem Evans, Ford
Corner store pump gas
10:1 compression ratio
D9 Block
Ford Racing, 521 nodular iron rotating assembly
Ford Racing, Ported, Super Cobra Jet. Oakley Motorsports
Ford Racing, M-6250-521 camshaft
Ford Racing, solid roller lifters
Double roller timing chain
Standard flow oil pump
Trend push rods
Crower SS rocker arms
Jomar stud girdle
Used Ported Ford Motorsports Intake Manifold
Jomar Power cone spacer
Quick fuel Black Diamond 4700 1050 2 circuit carburetor Oakley Motorsports
Edelbrock Water pump
MSD small cap distributor
Rear sump oil pan
SCJ Flow numbers Phillip Oakley ported
.200/I154/E103
.300/I234/E141
.400/I313/E175
.450/I346/E
.500/I371E203
.550/I382/E215
.600/I386/E228
.650/I372/E236
.700/I370/E243
.750/I373/E247
.800/I373/E248
Assembled & dyno'd by Jet Boat Bob
D9 Block
Trend push rods
Jomar stud girdle
Rear sump oil pan
.200/I154/E103
.300/I234/E141
.400/I313/E175
.450/I346/E
.500/I371E203
.550/I382/E215
.600/I386/E228
.650/I372/E236
.700/I370/E243
.750/I373/E247
.800/I373/E248
jones- Posts : 2230
windsor- Posts : 1167
Re: 521 Pump Gas build "Honey Bunny"
Bob told me over the phone that he didn't mess with any of the correction factors. I'm not sure what that means as I see on the dyno sheet there is some type of correction going on. He just mentioned that a lot of folks add some type of correction that bring the numbers up.
jones- Posts : 2230
What I find interesting is how similar my build is too Lem's other 521 pump gas build. The other engine was ran on a different dyno and I don't know what else could have been different. They look like twins on paper but mine has solid roller and victor intake. Maybe someone else could inform me.
jones- Posts : 2230
Nice results , looks like all your orders were filled
Gregaust- Posts : 626
The correction factors are to correct for weather and elevation (
barometer and temp changes) and also type of test standards like SAE.
jones wrote:What I find interesting is how similar my build is too Lem's other 521 pump gas build. The other engine was ran on a different dyno and I don't know what else could have been different. They look like twins on paper but mine has solid roller and victor intake. Maybe someone else could inform me.
Not twins at all.
The SFT engine had a Probe piston with a smaller dish than the FRPP piston = more compression.
The FRPP kit comes with a standard tension oil ring set. The SFT engine had a low tension oil ring package = less friction.
The SFT cam had a lot more exh. duration than the FRPP roller = i.m.o. helped the engine peak higher rpm.
Your engine was dynoed with 2-1/4 headers, the SFT was ran with D. Freelander's 2" headers. It remains to be seen which set was better...I'll let others debate that.
The SFT engine had a o.t.b. mafia intake and the FRPP engine had a ported Victor. Again, I'll let others debate the difference.
Of coarse different day different dyno is always a factor. Neither engines correction factors were jacket with, so I'm comfortable that the difference would be only a handful of hp.
The other engine was not "my project" although I did sell most of the componets in the engine.
Nice build Jones!
cheatham- Posts : 267
very nice numbers!! congratulations Jones
butterbean- Posts : 676
600ftlbs and over from 3700-5800rpm looks like it should have plenty of power to turn some tires over!
jones- Posts : 2230
Can't wait to see the truck! If you ever want to try it on the dirt drag, I have a set of cut tires you can throw on it to see what it's got! Muddy Joe's is coming up soon. You should try to make a race!
460bronco- Posts : 364
460bronco wrote:Can't wait to see the truck! If you ever want to try it on the dirt drag, I have a set of cut tires you can throw on it to see what it's got! Muddy Joe's is coming up soon. You should try to make a race!
I will probably do that, just don't know how long it will take to get the truck together. I've been bleeding Project funds all this time.
jones- Posts : 2230
Lack of funds or ADD will take over
the Coug- Posts : 3055
the Coug wrote:Lack of funds or ADD will take over
I hope the IS Sledge Hammer plate kit will hold me off on engine mods for a while. As far as funds go, I won't be able to paint the truck or run the Dash-Pak gauge cluster.
jones- Posts : 2230
jones wrote:the Coug wrote:Lack of funds or ADD will take over
That I-S plate is no joke !!!!
bruno wrote:jones wrote:the Coug wrote:Lack of funds or ADD will take over
I have sent Lenny a copy of my dyno results for him to price me a torque converter. He has all ready mentioned that he wished I used a Turbo 400 as those converters are built heavier duty. Him saying that kind of messed with me being that I have over $2,500 in a fully built c6.
jones- Posts : 2230
Get w/ frank on who builds his converters. Chad and I both have PTC units that have been working nicely.
I just got off the phone with Lenny. He really doesn't believe his normal 10" converters will hold, he is calling his vendors to see if he can get a billet unit and back in-touch with me.
jones- Posts : 2230
I updated the parts list to give credit where it's due. I really appreciate everyone that made this possible!
jones- Posts : 2230
» Pump Gas 502 Build
» Help with Big cube pump gas build..
» SPARK PLUG REFERENCE CHART
» Pump Gas Build some questions after dyno session..
» Pump Gas 523ci Fitech EFI 2x4 Dual Quad Build..PC manifiold pic's..
