AFR NEW HEADS
+45
gt350hr
BB94STANG
Carl
72mav
460pulling
4thHorseman
Gary Blair
466cj
whitefield
68galaxie
nitrous.f
Darrin Gorham
dirt_worker
D. Sea
Rickyt630x
butterbean
SLord82
wayney
Straubtech
DanH
Hardy
gmsmkr
QtrWarrior
BigRigTech
49 posters
Page 4 of 8
Page 4 of 8 • 1, 2, 3, 4, 5, 6, 7, 8
SAM's P-51
SAM's Popular Hot Rodding 532 P-51 used that cam for their "Off the shelf article". It had 11.5-1. It made 774 HP with ported heads and ported Victor on pump gas.
More testing needs to be done to be fair. Salesmanship goes both ways at times.
Gary Blair- Posts : 221
Re: AFR NEW HEADS
At this point I'm thinking AFR is late to the game is is just adding another choice, rather than providing any giant step up.
It's not good to need a dedicated intake and a 3rd valve location pistons either. The would have been better served sticking with the stock shape and location and producing a better intake on that platform.
afr
It wouldn't be the first time a new BBF head needed a different valve relief.
Seems like the AFR intake could be used on other BBF heads as well. Offering it with a CJ port would be a plus.
Re: AFR NEW HEADS
dfree383 wrote:At this point I'm thinking AFR is late to the game is is just adding another choice, rather than providing any giant step up.
I would kind of disagree. I think it's good to see people thinking outside the box on a street head. Until this point every street head has just copied the ford port dimensions and tried to work around it. I like the rectangle port as a new different option. The valve placement is only a bit of a nuisance for the time being. Having a dedicated intake is a good thing. As previously mentioned, even the Victor needed custom work to work well with an SCJ or P51 head.
All I see are positives with the valve layout being the only very minor hurdle until piston manufacturers catch up... Like they did when the SCJ first came out.
SLord82- Posts : 145
Re: AFR NEW HEADS
SLord82 wrote:dfree383 wrote:At this point I'm thinking AFR is late to the game is is just adding another choice, rather than providing any giant step up.
I'm just not convinced the 3rd valve relocation is worth the effort on a broad range street type head it just adds to the confusion and frustration to lower budget street guys wanting to upgrade. Same goes with the intake port..... Nothing new here either the square vs round argument has new going on For years and I'd be willing to bet 99% of the application won't ever see a difference either. It just comes down to marketing and convincing the average joe it's a new mouse trap.......
Guys who need a race head are going to pass right over these and get A460 or up parts. I see these as targeting the street and street strip guys.
Re: AFR NEW HEADS
+1
Race oriented builds will still use A460 or better starting points.
It certainly looks like the AFR head and intake will be a very decent OTB set up. That being said, the P51 and mafia intake is also
a very decent OTB set up as well.
I am sure we will see (hopefully) a build comparing P51/mafia intake on a 557 with the new AFR offering.
It is nice to see lots of choices - Not that long ago there were very few.
68galaxie- Posts : 351
Re: AFR NEW HEADS
I don't think anyone is pretending these are race orientated heads.
Whether they are better than all other street heads has yet to be seen, I just applaud the fact that AFR has created a completely clean sheet design for the 460. When was the last time this was done?
Yes, the valve location is a nuisance but I really doubt it will deter many from using a better option (if they turn out to be better). Was it really necessary to move the valves? Kaase thought so when he designed the SCJs and P51s and no one really questioned him. The intake manifold issue is a moot point. The heads WILL use CJ port intakes, but they also offer a dedicated intake. As for Rectangle vs Oval port, another moot point. They chose rectangle likely because thats what they know. They build tons and tons of BBC, LSx, SBC and SBF heads with RECTANGLE ports so why not stick with what works for them? Don't like it, don't use it.
Anyway you cut it, more options is always a plus and that's what I'm really excited about.
Maybe this will kick trick flow or edelbrock in the butt to create a new offering. Or maybe Ford or Kaase will update theirs. Maybe AFR sees a high demand and follows these with bigger better options similar to their BBC stuff. Shoot, maybe this will get world or dart to build us an aftermarket block if they see AFR become successful in a new market.
Re: AFR NEW HEADS
Based on the magazine stuff I hope I have this info correct.
Question is...if you were sitting at a stop light in your 3,300# Fox Mustang and some gay LS Chevy guy was in the other lane and you had one block to get it done....3,200 stall converter...which engine would you use?
1] 727 Hp @ 6,400 rpm - 674 lbs. ft. @ 5,000 rpm
2] 652 Hp @ 6,500 rpm - 649 lbs. ft. @ 4,700 rpm
3] 707 Hp @ 6,000 rpm - 694 lbs. ft. @ 4,800 rpm
Re: AFR NEW HEADS
engine number 3 is the winner
butterbean- Posts : 676
Re: AFR NEW HEADS
butterbean wrote:engine number 3 is the winner
Being that it makes 603 @ 4,600...I suspect you may be right.
Re: AFR NEW HEADS
Lem Evans wrote:Based on the magazine stuff I hope I have this info correct.
Lol at gay LS chevy guy. Though I really like those LS engines shhhhhhhhh.
Lem Evans wrote:butterbean wrote:engine number 3 is the winner
I also go with number 3. But I have 2 questions.
1. I recognize the 1 and 2 from the article but where did 3 come from?
2. Where did 603 @ 4600 come from?
Re: AFR NEW HEADS
[quote="SLord82"]
How dare you on this forum people have been banned for less...... .......J/K
gmsmkr- Posts : 1364
Re: AFR NEW HEADS
SLord82 wrote:Lem Evans wrote:Based on the magazine stuff I hope I have this info correct.
Lol at gay LS chevy guy. Though I really like those LS engines shhhhhhhhh.Lem Evans wrote:butterbean wrote:engine number 3 is the winner
#3
Re: AFR NEW HEADS
Lem Evans wrote:SLord82 wrote:Lem Evans wrote:Based on the magazine stuff I hope I have this info correct.
#3
What setup is #3?
Re: AFR NEW HEADS
I would try not to cry due to excessive laughing , realize he is beat with any of the above motors and not bother because the ticket is not worth it.
wayney- Posts : 187
Re: AFR NEW HEADS
Well a street driven (alot) Zephyr with a LS engine up here in Edmonton is damn fast.
I don't think anyone is laughing at his LS build - Just sayin.
315DR/275DR TT/LS powered Zephyr STREET CAR - 7.54@191.15 "Cream Dream 2"
Re: AFR NEW HEADS
68galaxie wrote:Well a street driven (alot) Zephyr with a LS engine up here in Edmonton is damn fast.
Does he have a 3,200 rpm converter? That was the context of my statement.
Flat tappets
Nothing wrong with solid FT cams. I like them a bunch. A good valve job and short turn work can be very rewarding on just about any head.
There is a nice pump gas 521 with early A-429's around hear with an Ultradyne SFT, 271/279 @ .050, 110, .642 gross. 10-1, Victor with a Holley 9377 1150. 345 CFM @ .600 lift on the intake
696 HP @ 6000
688 ft lbs @ 4800
Sometimes simple can be a lot of fun.
696 HP @ 6000
688 ft lbs @ 4800
Re: AFR NEW HEADS
Take the hair dryer or frosty off it and let's see it run.
Re: AFR NEW HEADS
All I can say is I am glad to see another offering and given time, I am sure there will be some dyno results posted here. And for the record, If AFR wants to send me a set of heads and intake, I'd be happy to bolt them on my 4.440x4.150 514 and dyno them out. Heck, I'd even get someone on this form to make a custom cam for the occasion..
Re: AFR NEW HEADS
dfree383 wrote:68galaxie wrote:Well a street driven (alot) Zephyr with a LS engine up here in Edmonton is damn fast.
....and get it done in a city block.
maverick- BBF CONTRIBUTOR
Re: AFR NEW HEADS
Lets get back on track here.
I have a BBF and love them!
I didn't like the laughing at an LS engine posting.
Not sure many street driven BBF could handle this LS street driven car. That is all I was saying.
Why do Ford guys have to belittle LS engines? I certainly like them better than the Ford Mod motors.
Anyhow, I like my BBF.
Re: AFR NEW HEADS
Coyote > LS. Just sayin'
4thHorseman- Posts : 400
Re: AFR NEW HEADS
68galaxie wrote:Lets get back on track here.
Last I checked the LS engine is produced by Government Motors....... We are Ford guys...... We don't like GM's as a rule when it's between domestic makes.... And we especially don't like GM engines being swapped into Ford cars.....Thats F'n wrong !
» A429 Heads VS Dove-c Heads
Page 4 of 8
