C6: help me fix 3rd gear buzz up
460bronco
Hardy
My granddad's 72 Mach 1, big block, c6 (trans brake) car has a chronic issue with not shifting into 3rd gear going down the track. 1st to 2nd is fine but when it gets to 3rd it falls on its face while the engine spins up about 5-600 rpm for a second before it shifts and then pulls fine. It's been an ongoing issue and we've had it rebuilt 3 x's in the last few years for this. Keeps coming back the same. Our trans guy says now that there is nothing they can do and c6 in in a heavy car behind an engine making any power will always do this, but we ran the car for 6 seasons with the trans working fine before this issue started, so I don't buy it.
Hardy- Posts : 107
Re: C6: help me fix 3rd gear buzz up
What 2nd gear servo do you have?
460bronco- Posts : 364
find a new trans guy!!
lghting94- Posts : 762
I'm not sure what servo is in it.... I texted my dad to try and find out. Tell me more about the servo and what might be goin on, if you don't mind. Have you guys heard of similar issues others have had or does this sound like a unique situation?
P.S. We are open to finding another trans guy for sure. My dad started going to this place way back because at the time he knew of no one else that could make a brake work in a C6, but we haven't been pleased with results lately
Hardy- Posts : 107
Talk to Frank Merkl
res0rli9- BBF CONTRIBUTOR
Not uncommon. What valvebody? If it is TCI bin it or Frank has a fix
Gregaust- Posts : 626
I know it's a billet valve body but I don't know who makes it. The trans was put together by automatic transmission design in Wisconsin. Based on everything I've read on this forum, I'm thinking we need to just get a hold of Mr. Merkl and figure out what we need from there
Hardy- Posts : 107
Franks valvebody and set up his way is the go and know it works
I'm about to build another C6 now exactly that. If Frank is busy or you need help just sing out
Can anyone get me contact info for Frank Merkl?
Hardy- Posts : 107
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
» 460 rotor gear connecting gear bad
