Stange 9 inch case advise needed
I got to get a strange case for my 69 cougar, it has the factory 9 inch in it now,
28 spline axles. Gonna upgrade to a strange case and 31 spine axles
Just not sure which one to get. 547bbf 700 plus hp 150hp nitrous.
cheatham- Posts : 267
Re: Stange 9 inch case advise needed
cheatham wrote:I got to get a strange case for my 69 cougar, it has the factory 9 inch in it now,
I use the 3.25" commonly referred to back in the day as the Daytona (big bearing). I would ask if you have bought your axles yet... and if you haven't why not use a larger 35-spline, I believe the cost is about the same.If it is drag only you can go bigger yet, but as I recall you were streeting it too!.
FalconEh- Posts : 1448
I'd go 35 spline too, and get the big bearing and 10 bolt Daytona pinion support. Give Quick Performance a shout he has great prices and awesome support.
schmitty- Posts : 4538
I just took my 35 splines out and went with 40 spline gun drilled. I'll be selling axles and spool here soon. Length was somewhere around 26" if I remember right.
70FB- BBF CONTRIBUTOR
» Advise needed for my cheapskate 460
» Mandrel Advise Needed
» Stud Girdle Install advise needed.
» Few things needed 9" nodular case, Moser 33 spline steel spool, Torino rear backing plates...
» 460 advise.
» 460 advise.
