X-pipe diameter
X-pipe diameter Empty X-pipe diameter
Post  MustangBBF July 2nd 2015, 8:32 am
Building exhaust on the Fox.
Ready all the stickies and searched the forums and did find the answer BUT....
Hate to build a 2.5 X pipe for a mild 460 and have to do it all over again for a 3". 460, DOVE-C Ported, 588/588 - 112 sep, Fuel Injected, Ported O sonic, I beams, blah blah, basic stuff. 400ish to the rear wheels.
Motor spec stickies call for a 2.5
Muffler back is 3" already. Switching from an oversized 3.5 X pipe and not wanting to have to redo the piping for a third time. Not sure the ~.25 diameter difference is a deal breaker between the 2.5-3 diameter. Shorty headers will be feeding the pipe and street only.
More than likely this motor will be redone/replaced due to specs being so poor.
Thanks,
Joe
MustangBBF
X-pipe diameter Empty Re: X-pipe diameter
Post  TravisRice July 2nd 2015, 12:35 pm
"Switching from an oversized 3.5 X pipe"
For just about any stock to mild 460 build I don't think you can go wrong with the 3" X-pipe. Remember that once you split the 3" to make the X-pipe section you are reducing the area in the merge section to begin with. The 2.5" with the X is going to be too small in my opinion. I am hoping that's a typo I quoted above as all the rest of your post refers to 2.5" .
X-pipe diameter Empty Not a typo
Post  MustangBBF July 2nd 2015, 12:52 pm
My old configuration with the long tubes had a TRUE 3.5 X pipe not a pipe notched X.
Switching to shorty headers and ditching 3.5 X Pipe. Dyno tuner said exhaust was to large and needed reduction.
based on the "stickies" on the engine build section, my HP lvl should have 2.5 exhaust to 3" mufflers.
I am just trying to avoid building the x pipe twice if I change motors.
MustangBBF
Post  dfree383 July 2nd 2015, 12:57 pm
The bigger the exhaust pipes the better
