got me another roller ..
butterbean
5pointslow
mini tubbed stock suspension fairmont from Nj
was a nitrous no time/Grudge ....made 740 rwhp when the previous owner had his nitrous small block in it
c
c
5pointslow- Posts : 1408
Re: got me another roller ..
has a 8.50 mild steel cage in it ,
a few things im not super warm and fuzzy about
Its mini tubbed but has a stock width 8.8 35 spline rear end ( why would you mini tub and not narrow the rearend a few inches )
and has c clip eliminators
lakewood 90/10 up front with coilover conversion (going to change these)
and most of all the Paint
Maybe it had a narrowed rearend at one time, and someone swaped it for some reason? Are you going big block or keep it SB?
supervel45- Posts : 4499
it has no motor in it
going bbf , i have some alum eddy heads im going to use that i got from a member there out of the box with cj ports cnc entry all stock from eddy
i have a stock crank ground 10/10 ...... thinking 466 good compression those heads a solid roller and see what it does ( car is very light )
My buddy is on my ass to do an Ls lol
he has a foxbody mustang with a junkyard 5.3 carbd with a plate ( springs and cam and carb and intake with headers ) it does run well for what it is , but
i cant do it ... i bleed blue
what tranny was in it? if it had a PG in it you could put a T-350 in the same place its all the same, drive shaft and cross member, really nice car good luck with it
butterbean- Posts : 676
[quote="5pointslow"]My buddy is on my ass to do an Ls lol
As long as he's down there, tell him to kiss it!
AZFairlane- BBF CONTRIBUTOR
Nice car. A lot of people don't narrow the housing and just use back spacing. on a fox mustang most of the good axles have enough spline to narrow each side 1 1/2 to two inch's. All you need with a mini tub. You can cut the axle with a abrasive wheel. careful not to get them too hot. It is pretty easy to do.
AZFairlane wrote:5pointslow wrote:My buddy is on my ass to do an Ls lol
^^^^^^^^^ this
gmsmkr- Posts : 1364
gmsmkr wrote:AZFairlane wrote:5pointslow wrote:My buddy is on my ass to do an Ls lol
^^^^^^^^^ this
Congrats car... BBBBF (Big Block Big Bottle Ford) and this^^^^^^
FalconEh- Posts : 1448
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» C460 Pistons+roller lifters and roller cams...
» Looking to trade a comp solid roller cam I have for a Hyd roller
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
» Using a soild roller lifter on a hydraulic Roller cam.
