563 TFS 325 nitrous build
gmsmkr
nitrous.f
10SHOTS
563 TFS 325 nitrous build  Empty 563 TFS 325 nitrous build
Post  10SHOTS August 10th 2015, 9:48 pm
tfs 325 heads milled to 76cc
tfs 4500 intake with induction solutions fogger
1250 dominator ,
4.300 eagle crank
6.800 eagle rods with 2000 bolt upgrade
Ross 4.566 13.6 compression 1/16 1/16 3/16 ring package with lateral gas ports
A-460 block , pistons .030 in the hole , .045 cometics
comp solid roller  116 lobe sep .839 lift , morel lifters
2 1/8 kooks headers , 4 inch collector
ptc converter , CSR aluminum flex plate ,power glide ,1.69 planetarys , 4.10 gears
30 10.5 Hoosier radials
results coming soon
new best , 12-20-15 1.16 60 foot,  5.04 at 138
on a 350 shot
10SHOTS
10SHOTS
563 TFS 325 nitrous build  Empty Re: 563 TFS 325 nitrous build
Post  nitrous.f August 11th 2015, 9:40 am
how much you spraying this time? Very Happy
nitrous.f
nitrous.f
Post  68formalGT August 11th 2015, 2:03 pm
How far along are you on the build?
Post  gmsmkr August 11th 2015, 11:01 pm
Twisted Evil get it done
gmsmkr
gmsmkr
Post  10SHOTS August 12th 2015, 7:37 am
[quote="nitrous.f"]how much you spraying this time?
what ever it takes to go into the 4s , probably 400-450
10SHOTS
10SHOTS
Post  10SHOTS August 12th 2015, 7:40 am
68formalGT wrote:How far along are you on the build?
it should be at the track first week of next month if there's no set backs
10SHOTS
10SHOTS
Post  richter69 August 12th 2015, 8:30 am
10SHOTS wrote:
nitrous.f wrote:how much you spraying this time?
Prob take more than that unless the car is super light.
Post  10SHOTS August 12th 2015, 8:36 am
3020 pounds , car has been 5.23on a 350 shot with a 284-298 114 camshaft , this cam might be going back in if I'm not happy
10SHOTS
10SHOTS
Post  68formalGT August 12th 2015, 10:59 am
Awesome, subscribed.
Post  Art August 12th 2015, 12:41 pm
Not trying to hi jack the thread but, our set up is similar, little more cubic inch and c heads, one fogger nos, flowed by Kevin Neal and we have been 4.92 at 146.8 for our best so far. Car weighs 3200 lbs with driver. That was around 400 shot with only a 1.23 60'. Still trying to figure this thing out.
Art
Post  larry552 August 12th 2015, 12:48 pm
Man ya'll have these hot rods getting it on. I hope mine run some good numbers when I spray it
larry552
larry552
Post  richter69 August 12th 2015, 1:00 pm
It took an additional 250 shot in a second kit to go from teens to 0's.... Those tenths are tough to shave off at that level.
I may be wrong.... I know i was at a point where the heads were tapped out no matter how much more jet I threw at it, the 4.3 crank wasnt helping either.
Post  10SHOTS November 28th 2015, 11:35 pm
5.15 backed up with a 5.16 at 135 on slicks , swapped to radials 5.06 at 137
10SHOTS
10SHOTS
Post  Larry T November 29th 2015, 4:21 pm
I think it wants a 3.89 or 3.70 rear gear and it will mile per hour better Wink
Larry T
Larry T
Post  richter69 November 29th 2015, 8:18 pm
This was w the bigger tune?
Post  10SHOTS December 21st 2015, 1:30 am
richter69 wrote:This was w the bigger tune?
350 shot , 34-36 nitrous jet 26 fuel  , 14.5 total timing
10SHOTS
10SHOTS
Post  10SHOTS December 21st 2015, 1:34 am
tonight's new best 5.04 at 138 with a 1.16 60 foot
ran motor one pass 5.71 at 123 in the 1/8 , 8.88 at 152 1/4 mile
4s coming soon
10SHOTS
10SHOTS
Post  larry552 December 21st 2015, 3:36 pm
Dam it looking good bro. And is that with the 350 shot
larry552
larry552
Post  10SHOTS December 21st 2015, 4:42 pm
larry552 wrote:Damage looking good bro. And is that with the 350 shot
yes
10SHOTS
10SHOTS
Post  FalconEh December 21st 2015, 10:37 pm
Cool cheers Just a matter of time... bounce
