Mounting a nitrous bottle straight up
Top Sportsman 514X
jones
I though I was told once that you would have to install a different tube in the bottle if you wanted to mount a lay down bottle vertical. Is this correct?
Does anyone sell vertical nitrous bottle holders?
jones- Posts : 2230
Re: Mounting a nitrous bottle straight up
I have seen them in McAmis' catalog. I have an Edelbrock in my car welded to the chassis straight up. Will be changing over to a dual mount over the winter!
Top Sportsman 514X- Posts : 41
When mounting a nitrous bottle upright I point the outlet fitting toward the back of the car so there's a greater chance the siphon (syphon?) tube will always pick up liquid nitrous (under launch loading) since the siphon tube inside the bottle normally points the same direction as the top outlet fitting.
http://image.hotrod.com/f/techarticles/9257402+w200/p105333_image_large.jpg
https://2img.net/h/i270.photobucket.com/albums/jj114/powertvmedia/06_Project%20Cars/NOS%20TBSS%20Install/bottleorientations.jpg
DILLIGASDAVE- Posts : 2262
To help maintain bottle pressure only use 50% of the nitrous in the bottle.
Buddy Thomas- Posts : 3
I agree with Dave on this one.. We actually mount the bottles in our car standing up right and pointing forward.. If we try and make a second pass on a set of bottles it will start to suck vapor and pop and bang... Looses about 5-6 MPH in the 1/8 as well.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Do you use 10lb or 15lb bottles? What determines the size bottles you use?
I was thinking of mounting a 15lb bottle behind my passanger seat standing straight-up.
jones- Posts : 2230
Even with a bigger 15 lb bottle, it would probably be smart to put in a fresh bottle every pass just for the sake of consistency. Well.....unless of course your using the small jets, then you might get to rack up a number of passes on one 15 pounder before volume/pressure drop too low.
Not what your asking but with my 15lbs bottle mounted in the bed in the normal brackets I can get 5 passes out of it with an 82 nitrous jet. Mounting it inside would be nice. I thought of mounting it sideways right behind the drivers side so I can reach the knob without getting out
droppedf100- Posts : 176
We run two 10# bottles in our car... SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
what about removing the syphon tube and running the bottles upside down?
adrenaline269- Posts : 35
» For Sale/NITROUS NOS PROGRAMMABLE NITROUS CONTROLLER #15834
» 240 or 300 straight 6 rod
» So when.
» straight axle
» BTE 1.80 Straight Cut Gear Set
» So when.
» straight axle
