Bottle warmer
Bottle warmer Empty Bottle warmer
Post  6jeff6 March 15th 2016, 10:03 am
What is a good bottle warmer to use on a 10lb zex bottle? Nothing fancy needed not a show car it's a go car.
6jeff6
6jeff6
Bottle warmer Empty Re: Bottle warmer
Post  supervel45 March 15th 2016, 10:12 am
https://www.google.com/search?q=crankcase+heater+for+scroll+compressor&sa=X&espv=2&biw=1366&bih=643&site=webhp&tbm=isch&tbo=u&source=univ&ved=0ahUKEwiL7Jub78LLAhXMtoMKHblgAVwQsAQIVA Trow one of these bad boys on there with an A/C convertor it will get hot quick.
Post  yellowhorse7 March 15th 2016, 11:07 am
Nothing Fancy? Blow torch....
Otherwise I like the NX Fire and Ice as well as the ARC 110v deal.
yellowhorse7
yellowhorse7
Post  gmsmkr March 16th 2016, 12:40 am
Love my NX fire and ice
gmsmkr
gmsmkr
Post  6jeff6 March 16th 2016, 7:55 am
Would I be able to spray a couple times without it so I can save up for one like that? Torch really isn't an option as bottle is mounted in front of the fuel cell just behind rear seat.
6jeff6
6jeff6
Post  yellowhorse7 March 16th 2016, 9:57 am
6jeff6 wrote:Would I be able to spray a couple times without it so I can save up for one like that? Torch really isn't an option as bottle is mounted in front of the fuel cell just behind rear seat.
Sure. Back in the ol' street racing days we'd turn the heat on in the tow vehicle and put the bottle on the passenger floor. I also have used the exhaust from my generator. Make sure the blow off is on it...
yellowhorse7
yellowhorse7
Post  6jeff6 March 16th 2016, 10:24 am
Thanks. If it's cool out and pressure isn't there I'll just run without it and get 60 foot down and shoot for lowest 10 I can get.
Now bottle pressure needs to be 925+?
6jeff6
6jeff6
Post  yellowhorse7 March 16th 2016, 10:56 am
6jeff6 wrote:Thanks. If it's cool out and pressure isn't there I'll just run without it and get 60 foot down and shoot for lowest 10 I can get.
If it's a nitrous deal then it probably won'y 60 worth a damn without the sauce. Regarding bottle pressure....that's a whole different can of worms. EVERYONE has an opinion on what they like and use and how much (or little) they have. Start at 925-975. That means as the car is in the first beam, the psi should be in that range
yellowhorse7
yellowhorse7
Post  6jeff6 March 16th 2016, 11:03 am
It 1.4x last year spinning no juice . This year launch is going up to 3,200 not idle and was only going to spray on big end in 3rd for 9 second slip
6jeff6
6jeff6
Post  Induction-Solutions April 5th 2016, 10:47 am
Here is the most common heater we sell and guys love it because it is a dual power.. Hope this helps.. SJ
http://inductionsolutions.com/shop/nitrous-accessoriescomponents/bottles-components/nitrous-bottle-warmers/
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
