Who makes a stub distributor (need it it turns oil pump only) F.I. Motor
Trentrent
Gents,
Using a Holley Dominator Fuel injection system with 8 individual coil packs. I gave a Wet sump oil pump, so I need a "stub" distributor for the oil pump shaft to mesh with the cam gear. Anyone know who makes one?
Trentrent- Posts : 11
Re: Who makes a stub distributor (need it it turns oil pump only) F.I. Motor
Just the drive - http://www.pricemotorsport.com/html/body_oil_pump_drives.html
As a cam sync - http://www.pricemotorsport.com/html/body_camshaft_synchronizer.html
windsor- Posts : 1167
Use one for a 351W and change the gear.
gt350hr- Posts : 662
We like using the one with a cam sync or just cut up an MSD billet distributor that you can buy online used for dirt cheap and build a cap for it and use an msd magnetic cam sync that you put into the cam gear. Easy stuff.
whatbumper- Posts : 3024
X2,on the Bill Price part. Bill is a good guy.
I am investigating a KFM offering for my belt drive distributor guys who run a wet sump. About a month away.
Keith
Keith
I used the Price Motorsports one. If you have gone to all the trouble of 8 coils you might as well get a cam sensor. I could be wrong but I thought you need cam and crank sensor for individual cylinder timing control with the Holley unit.
jasonf- BBF CONTRIBUTOR
» bbf motor plate with a danny bee belt drive
» who makes a vacum pump setup ,with alternator bracket and hub to work with front plate
» WTB Pump Gas stroker motor or strong pump gas 460
» want msd distributor for 460 and electric water pump @internal balance sfi balancer
» 552 ford pump gas motor
