2000 Mustang GT BBF Drag Week Build
dirt_worker
gmsmkr
frank13
2000 Mustang GT BBF Drag Week Build Empty 2000 Mustang GT BBF Drag Week Build
Post  frank13 April 4th 2016, 9:07 pm
Building a new car to get ready for this years Drag week. (on the wait list but near the top of it)
Starting with new to me car:
2000 Mustang GT BBF Drag Week Build IMG_0235_zpszfddmvfq
2000 Mustang GT BBF Drag Week Build IMG_0222_zpszwkzd65e
2000 Mustang GT BBF Drag Week Build IMG_0219_zpswlxck2zd
2000 Mustang GT BBF Drag Week Build IMG_0225_zpsjjk8cr2p
2000 Mustang GT BBF Drag Week Build IMG_0224_zps0ljotjms
2000 Mustang GT BBF Drag Week Build IMG_0243_zpswr7hjz4n
Got the car home and after some more exploration realized it needed some love. a lot of love.
Pulled the carpet and found this happiness:
just some surface rust.
2000 Mustang GT BBF Drag Week Build Rust%20floor_zpsnqa42blv
A little wire brush and some paint to clean it up for now:
2000 Mustang GT BBF Drag Week Build Cleaned%20up_zpsqyn7aybj
Some new parts to throw at it
Double adjustable rears:
2000 Mustang GT BBF Drag Week Build Darear_zps4iq8yolv
Single adjust fronts (same as on the car but these haventbeen used.
2000 Mustang GT BBF Drag Week Build Struts_zpslpbzxrli
old brakes
2000 Mustang GT BBF Drag Week Build Ol%20dbrake_zps4oxkpexd
test fit the new ones with the wheels
2000 Mustang GT BBF Drag Week Build New%20brake_zpsck8c3tq3
cleaning up the old spindles with new hubs. going to be black powder coat sans backing plate
2000 Mustang GT BBF Drag Week Build Rebuildinghubs_zpsfhko4jdp
8.50 cert on the cage
2000 Mustang GT BBF Drag Week Build 12249786_1206725796009512_1403516552919251269_n_zpsqdcblj9q
wire harness, old master, all brake lines, and new mounts for radiator needed to go:
2000 Mustang GT BBF Drag Week Build Front_zpsc7tzxnci
bye bye chopped up harness
2000 Mustang GT BBF Drag Week Build 12548915_1243718025643622_7887064694290973975_n_zpshl1w8yih
Jegs seat brackets for kirkey seats test fitting (little filing needed):
2000 Mustang GT BBF Drag Week Build IMAG0429_zpsbyevys0a
they look nicer than the stock cobraseats:
2000 Mustang GT BBF Drag Week Build IMAG0430_zpsnskxtcar
power with go through the powerglide
2000 Mustang GT BBF Drag Week Build IMAG0462_zps8mpinwft
Yup BBF motor, shortblock being started
2000 Mustang GT BBF Drag Week Build IMAG0475_zpsb3rxehvz
Painted the cage (firewall forward) with Hammered paint. Damn blue tarp makes it seem like i missed half the car! LOL
2000 Mustang GT BBF Drag Week Build IMG_20160221_085132_zpsxahgpdnm
2000 Mustang GT BBF Drag Week Build IMG_20160220_2318094_rewind_zpst7dtdsle
2000 Mustang GT BBF Drag Week Build IMG_20160221_094715_2_zps5evlkzub
2000 Mustang GT BBF Drag Week Build IMG_20160221_194535_zpsoyf3cvzq
First day of wiring. Taking a little longer than anticipated since the window and door locks were a last minute undertaking. No matter how hard I tried, I could not get the factory system working. Oh well, just going to make it work directly from each component and wire from there to new relays and switches. I think i Have a plan to make it look factory.
So far I have the headlight,front parking, and front turns ran to the dash (not terminated into the relay panel yet). I will be using the Bussman RTMR relay panels for the chassis harness (lights, windows, trunk popper, ect) and an ARC 8000 for engine stuff (fans, water, starter, ignition, fuel, trans cooler fan)
Protective loom even in the door! Got rid of the entire factory harness in the doors, rewires the locks and windows (just cause)
2000 Mustang GT BBF Drag Week Build 00000000-0000-0000-0000-0000273b7cd7_zps4bmc1dnl
Headlight harness- passenger side. DT connectors, abrasion protection, and dual wall shrink wrap.
2000 Mustang GT BBF Drag Week Build 00000000-0000-0000-0000-0000273b7cf5_zpsr8gufffz
Drivers Side - same connectors as passenger side- you can see the grounds- will be fully bolted to a ground lug attached to the frame rails
2000 Mustang GT BBF Drag Week Build 00000000-0000-0000-0000-0000273b7cf7_zpszhhtepdr
2000 Mustang GT BBF Drag Week Build 00000000-0000-0000-0000-0000273b7cf4_zpsvtluvfd8
One window down! One to go!
2000 Mustang GT BBF Drag Week Build 00000000-0000-0000-0000-0000273b7cf1_zpstdjimpgg
Using the Bussman Fuse and relay blocks to get everything terminated. I probably could have used a couple less connectors but I wanted things to be able to be serviced or added on to easy.
Bussman relay panel:
2000 Mustang GT BBF Drag Week Build IMG_20140213_0014249_rewind_zpsujwbryfa
Turn signal switch repinned for the DT connector. I am not using the wiper side, nor am I am using the high beam wiring, although I left the ability later on.
2000 Mustang GT BBF Drag Week Build IMG_20140213_0015063_rewind_zpsevkvr7oo
The backside of the Bussman panel- the Fuse side is bussed possitive, the relay side is bussed on the negative terminal. Really easy to wire up.
2000 Mustang GT BBF Drag Week Build IMG_20140213_0014407_rewind_zps8ornnnbe
Just the harnesses from the Bussman switch side and the Power/output side. I loomed it all and used shrink wrap on the ends.
2000 Mustang GT BBF Drag Week Build IMG_20140213_0015175_rewind_zpsihbkabck
Headlight harness from the switch to the front of the car. The red and white wire(inline brake switch wire) will be loomed with the wire from the line lock once they are in place.
2000 Mustang GT BBF Drag Week Build IMG_20140213_0013593_rewind_zpsrtr5ycsy
The whole kit minus the rear of the harness. I probably have 4 days into this easy (i kept redoing it till I was happy with it) Could probably make another in a day using this as a template.
2000 Mustang GT BBF Drag Week Build IMG_20140213_0016003_rewind_zpszxdrji4q
Little video of bench testing it. Finally getting the lights to work off the factory switch.
https://vid455.photobucket.com/albums...pse7dhis1i.mp4
frank13
frank13
http://www.frankskinkracing.com
2000 Mustang GT BBF Drag Week Build Empty Re: 2000 Mustang GT BBF Drag Week Build
Post  gmsmkr April 4th 2016, 9:16 pm
I did all this the first go around with mine also. now I have manual windows and blinkers on a toggle switch my head lights on the factory switch I took another 5lbs out of mine with the new wiring almost 25lbs out going to manual windows.
Looking good
gmsmkr
gmsmkr
Post  dirt_worker April 4th 2016, 9:20 pm
Great lookin project! Cant wait to see the finished product Cool
dirt_worker
dirt_worker
Post  frank13 April 4th 2016, 9:28 pm
gmsmkr wrote:I did all this the first go around with mine also.  now I have manual windows and blinkers on a toggle switch my head lights on the factory switch I took another 5lbs out of mine with the new wiring almost 25lbs out going to manual windows.
Looking good
what year car?
frank13
frank13
Post  FalconEh April 4th 2016, 9:45 pm
Same Gen as yours, looking good nice to see more BBF's representing at Drag Week!
Post  gmsmkr April 4th 2016, 10:53 pm
Looking good
what year car?
2000
gmsmkr
gmsmkr
Post  frank13 April 5th 2016, 12:13 am
got any pics?
frank13
frank13
Post  gmsmkr April 5th 2016, 12:30 am
frank13 wrote:got any pics?
My build is on here under mustang pics
2000 Mustang GT BBF Drag Week Build 20150626_195336_zpskffnma37
gmsmkr
gmsmkr
Post  frank13 April 5th 2016, 1:14 pm
Out of curiosity. Where did you get the manual stuff????
Only place I saw it was over 300 bucks.
frank13
frank13
Post  gmsmkr April 5th 2016, 1:29 pm
From 94-98 mustang v6 from junk yard it was 10$ ea for the internals.....
What we have are called new edge chassis but they are known as a sn chassis if that makes sense so any part from 79-04 will work with out alot of mods
My car has a fox rear width and all with the all fox internals which narrowed it by 2"s I have post on regarding all the mods for our chassis if you need any help just ask I will post more
gmsmkr
gmsmkr
Post  quick 52 April 11th 2016, 6:27 pm
Have done DW a couple times with a 460 Ford had a blast... I'm on the waiting list also see you at DW
quick 52
Post  69F100 April 11th 2016, 7:57 pm
looking good Frank did you sale your other car
Post  frank13 April 12th 2016, 10:39 pm
Ok, so to leave well enough alone is not my thing. I have looked through every wiring thread known to man and decided to make a cosmetic change. Along with that change was an order to DelCity for some finishing touches on the panel and the power distribution. Now once the panel is bolted in I can leave it in and keep the battery hooked up so I can open the windows and pop the trunk (putting the windows down makes moving the car easier by myself)
FIrst off some supplies. 4 gauge power wire for the starter and to the panel. Some 6gauge for floating grounds for. Along with some different sized lugs and boots for safety. Picked up a couple pass through for the firewall.
2000 Mustang GT BBF Drag Week Build IMG_20140222_0408526_rewind-1_zpspch093gd
Nice and flexible wires!
2000 Mustang GT BBF Drag Week Build IMG_20140222_0409064_rewind_zps4r9tjywi
2000 Mustang GT BBF Drag Week Build IMG_20140222_0409206_rewind-1_zps2rugxaud
Now for some small changes. I used two plugs for the input and outputs of the panel. Well, I was not always happy with them floating around, even when tied to the panel. SO I decided to step up to the Duestche HDP-20 panel mount connectors. Simple change but i think it will be worth it in the end as I will be happier. Even got some boots to make it all pretty. I didn't use Raychem for this stuff as I think I may add nitrous in the near future and wanted to be able to make a simple change to the harness.
2000 Mustang GT BBF Drag Week Build IMG_20140222_0404073_rewind-1_zps4byipd5y
Connectors and more connectors. AND boots!!!!
2000 Mustang GT BBF Drag Week Build IMG_20140222_0403216_rewind-1_zpsxpqktdyr
Little close up!
2000 Mustang GT BBF Drag Week Build IMG_20140222_0409425_rewind_zpslei9spzo
I just think this works better and looks better, and we all know if you can not be fast, you better look good!
2000 Mustang GT BBF Drag Week Build IMG_20140222_0405418_rewind_zpsuluqr87i
SO the goal is to have this permanently mounted this week. Get the engine in and then run the wire and stuff for that!
frank13
frank13
Post  frank13 April 12th 2016, 10:40 pm
[quote=MrScharfenberger;1543218]Very Nice!! Doing Drag Week would be awesome.
I'm not sure if you got the windows done or not yet but the below info was a post on my build thread. It is a 1993 but perhaps the connectors & wiring stayted the same.[/quote]
Oooooooooooooooh I almost forgot.....Power windows are a go! With the help of a couple YB'ers we finally have success!
Let me leave this video here!
https://www.youtube.com/watch?v=wqLFdmcHkmg
frank13
frank13
69F100 wrote:looking good Frank did you sale your other car
Currently its a parts car.
frank13
frank13
Post  gmsmkr April 12th 2016, 11:02 pm
Nice work it should look clean when completed
gmsmkr
gmsmkr
Post  69F100 April 12th 2016, 11:27 pm
[quote="frank13"]
Currently its a parts car.  [/quot
I see you still got your helper helping you or she into boys and no time to help you any more
Post  frank13 April 14th 2016, 11:47 pm
So a little change of pace from the wiring. I have decided that to get things finalized with wires and such, I need the shortblock, converter and trans in the car. Sooooooooo down to the tiny tiny space I call the basement.
So I already had the shortblock together, but a change in direction (a 150-250 shot of nitrous) I had to pull it apart and open the ring gap a tad)
The machine shop did all the clearances for me when they fixed the crank and honed the block, but I wanted to double check so out came the plastigage.
2000 Mustang GT BBF Drag Week Build IMG_20140224_0000484_rewind_zpsi3hnqjrt
dead on at .003
2000 Mustang GT BBF Drag Week Build IMG_20140224_0000420_rewind_zpsostnnazy
So the crank is spinning nice and smooth!!!!!!!
https://www.youtube.com/watch?v=Ec_TcbZKTOs&feature=youtu.be
Here are some pics of the parts going into the shortblock:
2000 Mustang GT BBF Drag Week Build IMG_20140223_2341258_rewind_zpsdnkuuxqg
2000 Mustang GT BBF Drag Week Build IMG_20140223_2235272_rewind_zpsos1ccsx6
2000 Mustang GT BBF Drag Week Build IMG_20140223_2235211_rewind_zpsno6ak2vt
2000 Mustang GT BBF Drag Week Build IMG_20140223_2234512_rewind_zpsh7zz4ehn
2000 Mustang GT BBF Drag Week Build IMG_20140223_2235300_rewind_zpssabieinu
2000 Mustang GT BBF Drag Week Build IMG_20140223_2235319_rewind_zpsixculvbm
Starting to check the ring gap:
2000 Mustang GT BBF Drag Week Build IMG_20140223_2234475_rewind_zpsk7pyyghr
2000 Mustang GT BBF Drag Week Build IMG_20140223_2235152_rewind_zpswsakb5k4
2000 Mustang GT BBF Drag Week Build IMG_20140223_2235114_rewind_zpsuttz6msw
2000 Mustang GT BBF Drag Week Build IMG_20140223_2235180_rewind_zpsgtc8huhm
Oh, are you wondering why I dont have video of the shortblock being spun nice and smooth? Well. Here goes:
2000 Mustang GT BBF Drag Week Build IMG_20140224_0347235_rewind_zpsls7wcjnq
Oops......Gotta order a set of damn rings now. (yes a set......one ring pack is 32 bucks, a complete set can be had online on sale for 82 bucks. I will just have some spares)
frank13
frank13
Post  frank13 April 17th 2016, 9:52 pm
Ok so back to building the shortblock! So I was able to get a set of rings the same day from my engine guy. Crisis averted.
Got everything together and poof I have a complete rotating assembly installed. Or so I thought! I am new to all this stuff so the gents who give me tech advice and talk me through stuff asked about end play and rod clearances.
So feeler gauges come out and viola- we have the correct rod clearnaces! Sweet! Then crank end play. I was at the shop when they redid my crank and installed it in the block and we had the .006 end play, BUT , I do not have it now. No big deal, pull the rods off and check again. Nope. less than .004. Give it a whack after loosening the main caps. Nope. Same. Fast forward to today, and I have an actual dial indicator, some 1000 grit paper, some glass, and hopefully a lot of patience waiting for amazon same day shipping to show up!
I think after 4 hours I have it right.
Just at 6 at full 110ftlbs
That was not fun at all!
https://www.youtube.com/watch?v=SzwbVSVsZ50&feature=youtu.be
Piston and rod reinstall next! For the 103984 time!
Well once I figure out the ARP stud, canton pan, canton windage tray issues.
frank13
frank13
Post  frank13 April 24th 2016, 7:36 pm
And we have a rotating assembly!
Clean bore is a happy bore
2000 Mustang GT BBF Drag Week Build IMG_20160424_1239221_rewind_zpshopxn1xu
Cleaned painted and ready to go!
2000 Mustang GT BBF Drag Week Build IMG_20160424_1239134_rewind_zpsp5wanowt
2000 Mustang GT BBF Drag Week Build IMG_20160424_1235011_rewind_zpsuattmtpd
2000 Mustang GT BBF Drag Week Build IMG_20160424_1234165_rewind_zpsd5yuwydb
Cam plate from Lem
2000 Mustang GT BBF Drag Week Build IMG_20160424_131914_zpsjjb3bdw0
Every nut and bolts gets chased!  Every thing
2000 Mustang GT BBF Drag Week Build IMG_20160424_131926_zpsvhnqg0if
Cleaned, cut, cleaned again.
2000 Mustang GT BBF Drag Week Build IMG_20160424_132246_zpsbuueqvkx
Clean oil on the threads going into the block
2000 Mustang GT BBF Drag Week Build IMG_20160424_132319_zpst5sjhxtm
Crank bearings are in
2000 Mustang GT BBF Drag Week Build IMG_20160424_133208_zpscgxqsj8d
And now have some "blood" on them
2000 Mustang GT BBF Drag Week Build IMG_20160424_133417_zpsdog3lplnBeep beep beep.  We have studs!
Crank is in for the last time I hope
2000 Mustang GT BBF Drag Week Build IMG_20160424_133709_zpscronpvcb
2000 Mustang GT BBF Drag Week Build IMG_20160424_135042_zpswkhiq3kt
Feeling cappy?
2000 Mustang GT BBF Drag Week Build IMG_20160424_141058_zpsa6zcloea
ARP ultra torque.   Nice and heavy!
2000 Mustang GT BBF Drag Week Build IMG_20160424_143103_zpsh1yixe7q
Went through A LOT  of lube!
2000 Mustang GT BBF Drag Week Build IMG_20160424_143116_zpsbwm205pb
And we are done for tonight.    Cant find the damn crank bolt.   So i am done for tonight.
2000 Mustang GT BBF Drag Week Build IMG_20160424_1723528_rewind_zpsssmzm04u
frank13
frank13
Post  68galaxie April 26th 2016, 5:30 pm
Sweet Build!
I assume 466 cubic inches?
SCJ or P51 heads being used?
Looks like a comp solid roller - nitrous grind?
Cheers
68galaxie
68galaxie
Post  frank13 April 26th 2016, 7:01 pm
68galaxie wrote:Sweet Build!
I assume 466 cubic inches? Yup
SCJ or P51 heads being used? Heavily ported SCJ heads.
Looks like a comp solid roller - nitrous grind? Lunati cam. Here is a pic of the cam card:
2000 Mustang GT BBF Drag Week Build 12038026_1196076423741116_8614472177713462107_n_zpsnegl4scw
Cheers
frank13
frank13
Post  frank13 April 30th 2016, 10:57 pm
Windage tray and oi pump final install
2000 Mustang GT BBF Drag Week Build IMG_20160430_1557065_rewind_zpspvgcqg6x
Little primer to get rid of the ugly gold canton color
2000 Mustang GT BBF Drag Week Build IMG_20160430_1556533_rewind_zpsdinnusil
Better!
2000 Mustang GT BBF Drag Week Build IMG_20160430_1621019_rewind_zpsgodtxktv
Timing cover with the same black as the block
2000 Mustang GT BBF Drag Week Build IMG_20160430_1620548_rewind_zpsemxeved7
Black and SS look great
2000 Mustang GT BBF Drag Week Build IMG_20160430_2212209_rewind_zpsz4zl7wk1
2000 Mustang GT BBF Drag Week Build IMG_20160430_2212358_rewind_zps7lvygqtj
Tomorrow morning it comes off the stand and gets mated to the trans and converter then into the car!
2000 Mustang GT BBF Drag Week Build IMG_20160430_2213091_rewind_zpsrpywv2zf
The trans its getting mated to!
2000 Mustang GT BBF Drag Week Build IMG_20160430_1557320_rewind_zpssn6ptcot
Converter installed on the trans
2000 Mustang GT BBF Drag Week Build IMG_20160430_1557256_rewind_zpsxwetxz8c
frank13
frank13
Post  frank13 May 13th 2016, 11:08 pm
Ok, so pushrods are measured up and get ordered on Monday,
2000 Mustang GT BBF Drag Week Build IMG_20160513_1745176_rewind_zpsdzt8z90q
2000 Mustang GT BBF Drag Week Build Imagejpeg_2_zpsk4ujzfgz
2000 Mustang GT BBF Drag Week Build IMG_20160513_1743586_rewind_zpsntyywu4v
2000 Mustang GT BBF Drag Week Build IMG_20160513_1743224_rewind_zpsb0c1waid
Ended up with a 9.250 exhaust and a 9.1 intake.......................
frank13
frank13
