93 F150 528cu project build
+28
Big block fox 339
Northwest outlaw
ThndrChkn
96Mustang460cid
blown473
blown86hallet
Copperhead
70bbftorino
Greg_P
D. Sea
racerk_2000
'65 T-BOLT
longroofracer
droppedf100
sixtynineford
Blue Oval Forever
jones
32 posters
Page 4 of 6 Previous  1, 2, 3, 4, 5, 6  Next
93 F150 528cu project build - Page 4 Empty Re: 93 F150 528cu project build
Post  96Mustang460cid March 28th 2010, 1:08 pm
You should be able to find an EVTM (Electrical Vacuum Troubleshooting Manual) for your Lightning. I found one for my 96 Mustang on Ebay a few years ago. The EVTM is what the Ford Technicians use in the shop. They're the best wiring diagrams I've ever used. They're WAY better than the Chilton's and Hayne's diagrams!
When I start dissecting the wiring harness on my 2003 F150, I'll use one too.
Have a good day!
Michael
96Mustang460cid
96Mustang460cid
Post  jones April 5th 2010, 12:12 am
Thanks, I"ll have to find one.
jones
Post  jones April 5th 2010, 10:36 am
Transmission is bought and should be on the way in a couple of weeks!! Decided to go with the Broader c6, it's basicly his 1000hp transmission he offers except I will install the cast pan and little other items like that that would normally come on the 1,000hp unit! Can't wait for it to get here! Now all I need is a converter, driveshaft, cylinder heads and harmonic dampener.
Thanks to Doug I bought his manual powersteering box, so now I don't have to worry about the powersteering pump and brackets.
jones
Post  ThndrChkn April 5th 2010, 10:51 am
jones wrote:
'65 T-BOLT wrote:looks good enough to me! I would be happy with that install. Even thou the straps are bowed a little. Maybe could have used 4 little spacers under the factory tabs on the cell and bolted tit to the bed that way! ..just a thought!
Wouldn't pass tech, plus the tabs are really weak. I would have mounted the straps right over the tabs, but if you notice the return and vent bung is in the way.
Why wouldn't your fuel cell pass tech? I ran mine for more than a season strapped to the bed just like that and they never said a word, except when I forgot to install the ground strap. You're welcome Josh for the manual box. Just having that on there, has to take over 20# off of the front.
Doug... Cool
ThndrChkn
ThndrChkn
Post  jones April 5th 2010, 11:02 am
I thought I read in the NHRA handbox that the fuel cell hast to have straps? It's done now and doesn't look that bad. It will look better once I get the battery box and the bed painted.
When I do bring the truck to the Bash I don't want to get all the way up there and not pass tech.
jones
Post  jones April 5th 2010, 11:05 am
What do ya'll think about wheelie bars on this truck?
jones
Post  dfree383 April 5th 2010, 11:09 am
Na, See how she does first.
Post  jones April 5th 2010, 11:16 am
Ya' I was just thinking out loud there for a moment. I have to work on finding the right cylinder heads for this package. Thought about just buying a set of TFS out of the box. Since I am only running a hyd flat camshaft and J429 intake. Then when I get enough money for a solid roller setup I could have the heads ported.
The main question is right now, is do I want the 74cc TFS or try to find a set of 100cc Blue thunders. From what I can tell is the TFS flow better tha the BT and I'm not 100% sure the BT would need a different valve notch in the pistons.
jones
Post  ThndrChkn April 5th 2010, 2:42 pm
I believe the BT heads will work with the stock pierce point on the pistons. I'd probably just go with the TFS's with the FT Hyd. cam. Like you said, there's always room for porting too as the funds allow for further upgrades.
Doug... Cool
ThndrChkn
ThndrChkn
Post  dfree383 April 5th 2010, 2:54 pm
TFS Streets will work with the weight of your Truck better IMO. They work awsome and will get you some great compression. Your looking to go FAST right???? Compression is your Friend !!!
Post  jones April 5th 2010, 3:05 pm
I agree, just wondering if I would have any reason to lower the compression ratio.
jones
Post  dfree383 April 5th 2010, 3:07 pm
jones wrote:I agree, just wondering if I would have any reason to lower the compression ratio.
If your racing Hell No !! You could use more !!! But you got what you got now, so run it !! and when it wears out, get some domes in their........
Post  jones April 5th 2010, 3:13 pm
Well, I guess I am just flapping my jaws because I know what I need then. What are you suppose to do between waiting for stuff to come in and saving money??
PS. I think I talked my way out of the whole tractor thing! Laughing
jones
Post  dfree383 April 5th 2010, 3:15 pm
Thats good ! To much money and interest to spend for something you don't need and already have.
Post  jones April 5th 2010, 3:20 pm
Laughing I guess I better get my father in-laws golf cart back running before he starts in on something else.
I have nothing to do on the truck, it's just sitting there waiting for parts. Called Broader today and they said it would be a couple more weeks before the transmission is ready. Why ain't nothing free? Laughing
jones
Post  jbozzelle April 5th 2010, 9:25 pm
You better call Lem and get dibs on some Streets before you change your mind again.....
Or there is that set of Victor heads in the classifieds for sale......
Post  jones April 5th 2010, 11:41 pm
jbozzelle wrote:You better call Lem and get dibs on some Streets before you change your mind again.....
It would be nice to come home from the Bash with another set of heads.
jones
Post  jones April 24th 2010, 8:19 pm
Decided to go ahead and start on the interior. I have to do some welding on the floor anyway so the interior has to come out.
93 F150 528cu project build - Page 4 006-1
Parts at the end of the bed are going to the scrap bin
93 F150 528cu project build - Page 4 007
Only part coming back in.
93 F150 528cu project build - Page 4 008
jones
Post  jones April 24th 2010, 8:22 pm
Does anyone know where I can find a replacement dash pad that goes on the passanger side part of the dash? I guess I could just re-wrap it.
jones
Post  jones April 24th 2010, 9:48 pm
Dash is back in.
93 F150 528cu project build - Page 4 009-1
Anyone got some 20" Kirkeys for sale?
jones
Post  Northwest outlaw April 24th 2010, 10:15 pm
cool deal looking good.
Northwest outlaw
Northwest outlaw
Post  jones April 24th 2010, 10:18 pm
I'm going to work on sealing the firewall and floor board up a little better. Just incase of fire and exhaust fumes. The firewall is lookss about like swiss cheese!
jones
Post  Big block fox 339 April 28th 2010, 10:29 pm
jones wrote:I'm going to work on sealing the firewall and floor board up a little better. Just incase of fire and exhaust fumes. The firewall is lookss about like swiss cheese!
what you gonna use to seal up your Swiss cheese cause mine looks the same way and the e85 fumes are killing me on the street
Big block fox 339
Big block fox 339
Post  jones April 28th 2010, 11:22 pm
I am going to try to weld in patch panels.
jones
Post  D. Sea April 29th 2010, 12:04 pm
Josh,
I believe Joe Mayabb is a dealer for Kirkey?
http://joemracing.tripod.com/
D. Sea
D. Sea
