How tight should the balancer spacer be on the crank?
How tight should the balancer spacer be on the crank?  Empty How tight should the balancer spacer be on the crank?
Post  paperman May 26th 2016, 11:20 am
I picked one up that is hard anodized aluminum and its going to take some metal removal the make it fit.  Its almost 2 thou small, should this be a slide or interference fit?
paperman
How tight should the balancer spacer be on the crank?  Empty Re: How tight should the balancer spacer be on the crank?
Post  gt350hr May 26th 2016, 12:02 pm
Slide on for sure , not an interference fit. The maker probably forgot about the "build up" when parts are anodized. You need to hone it.
gt350hr
Post  paperman May 27th 2016, 11:26 am
That's what I suspect as well. A few thou on the OD is no big deal as the seal is pretty forgiving, the crank on the other hand is not. Thank you.
paperman
Post  dfree383 May 27th 2016, 12:51 pm
Some aftermarket crank snouts can be on the high side too.
