Making a oil priming shaft.
+6
Super Snake Steve
75truck
10 posters
I am trying to make an oil pump primer out of an old duraspark distributor. Is there a small bolt that holds the cogs on the upper shaft that has to be removed to get the cogs off?
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Making a oil priming shaft.
Roll key holds the star on but a funky snap ring down in the top of that shaft holds it on.
I just use a thinwall socket on a long 1/4" drive socket extension. I tack weld the socket on the extension so that I don't hyperextend my vocabulary (cuss because the socket went somewhere it shouldn't). The end of a 1/4" extension fits nicely in a 1/2" drill chuck.
maverick- BBF CONTRIBUTOR
maverick wrote:I just use a thinwall socket on a long 1/4" drive socket extension. I tack weld the socket on the extension so that I don't hyperextend my vocabulary (cuss because the socket went somewhere it shouldn't). The end of a 1/4" extension fits nicely in a 1/2" drill chuck.
X2
X5 six point.
Pry that "star" wheel up with a pair of flat blade screwdrivers. Then the snap ring underneath can be removed and the whole plate,, pickup, etc... can then be removed.
I usually just use a deep 5/16", 1/4" drive 6pt socket and duct tape it to my long extension then attach the cordless drill and let it rip...
jbozzelle- Posts : 3705
rmcomprandy wrote:Just a plain old distributor SHAFT works for me.
Same here.
BigRigTech- Posts : 763
BigRigTech wrote:rmcomprandy wrote:Just a plain old distributor SHAFT works for me.
Same here.
^^^ This.
DILLIGASDAVE- Posts : 2262
» Timing Pointer for Stock Timing Cover
» Priming oil pump on a short block
» Won't be making it to the bash
» how much hp do you guys think my 466 is making?
» Making some progress
