Spun Bearings
Spun Bearings Empty Spun Bearings
Post  bbcoupe June 30th 2016, 4:01 am
Racing a few weeks ago and noticed oil pressure gauge fluctuating after run so packed it up for the trip home.
On tear down found oil pump pick up sitting on bottom of pan.
Spun 2 rod bearings.
Scat 9000 series 4.500 crank
Machine shop says there's a 7thou bend in the crank which they say can be ground out by going .020 on the journals.
Machine the crank or replace?
Spun Bearings 20160620_191450_zpsljvdaju5
Spun Bearings 20160620_192434_zps4bax6yqu
Spun Bearings 20160620_192347_zpsk2ysg3x0
Spun Bearings 20160622_170756_zpssntnh5gz
Spun Bearings 20160622_170743_zpsgcx7apdk
Spun Bearings 20160622_170922_zpsmhxloyr2
Spun Bearings 20160622_170850_zpsdcdizk24
Spun Bearings 20160622_171047_zpsklgoelxe
bbcoupe
https://www.youtube.com/user/coupe545
Spun Bearings Empty Re: Spun Bearings
Post  Scott Foxwell June 30th 2016, 8:45 am
Any decent machine shop should be able to straighten the crank before they grind it.
Post  Scott Foxwell June 30th 2016, 8:47 am
Post  dfree383 June 30th 2016, 8:52 am
I'd just fix it, didn't get too hot.
Post  gt350hr July 1st 2016, 2:01 pm
+1 I have a FMS 514 (Scat 9000) crank that looked like that. Cleaned at .010 under and the mains stayed std. No problem.
gt350hr
Post  bbcoupe July 1st 2016, 9:14 pm
Is already at .010 that's where the .020 grind recommendation come from, and more than another .010 and bearing choice becomes a challenge.
bbcoupe
