Running HOT
Running HOT
I just completed a 521 cu in stroker build and it's running about 230 deg while at cruising speed 25 to 45mph on a 65deg day. It will also overheat sitting at an idle. I haven't taken it much faster yet for fear of boiling over. The engine block is a 1974 vintage, heads are 1968 cast iron. I'm running a 160deg thermostat with a 19"X34" aluminum radiator with twin electric fans, headers, dual 450cfm holley carbs on a tunnel ram intake, Mother Thumper cam, factory serpentine belt set up off of a 95 460 using the 95 vintage waterpump mounted on the 74 vintage timing chain cover, MSD distributor & 6AL box. Trans is a C-6 with a 2000-2500 stall converter. I got an engine gasket kit free from a friend but it turned out to be for a fuel injected engine. I found this out after I had the motor in the car. We compared new head gaskets and couldn't see any differences between the two. I have been told they won't interchange but I can't see why. Is there really a reason they won't work? Is there something I missed with mating up the 95 waterpump to the 74 timing chain cover? Any other suggestions? This combination was installed in a 1989 Crown Victoria station wagon.
Obnoxus- Posts : 5
Re: Running HOT
Sounds like a wild combo!!
The biggest issue seems to be getting all the air out, is the rad the highest spot in the system? Sometimes jacking the front of the car up will help it burp!
Bill
Bill
billandlori- Posts : 2081
Re: Running HOT
If you have a Thermo-temp gauge (laser) check side to side Exhaust and see if one side is hotter (potential gasket problem), is the serpentine belt ran correctly over the WP pulley or is it reversing the rotation, remove the thermostat and check if temps diminish. Is the timing correct, and is the cap holding pressure or does it bleed it off. A few things to look at as well as the air lock mentioned.
FalconEh- Posts : 1448
Running Hot
I will try jacking up the car, the upper hose has a bend in it that is a little above the radiator. I pulled the thermostat without draining the radiator any more than just below the upper hose connection and there was antifreeze filling the manifold right to the bottom of the thermostat. I will also check the exhaust temps side to side. The timing is at 11 deg btdc. I have also been richening the carbs which has helped a little. Thanks for the help
Obnoxus- Posts : 5
Re: Running HOT
The biggest mistake that first time big block Ford builders make is that ONE head gasket is installed upside-down and causes overheating.
The SQUARE corners on the lower edge of the head gaskets are supposed to go toward the front of the engine and the round corners to the rear.; (one gasket side is reversed from the other side).
Running Hot
Just an update. I am narrowing it down to an air flow problem. First of all I discovered tonight that there was a plastic, factory block off plate on the backside of the grille. It covered
the top 1/4 of the grille opening. After removing this, I drove down the highway at 65mph 2500rpm and the temp never got over 190. when I slowed down and stopped it climbed to 230 but dropped back to 210 when I got moving at 25-35 mph. Back on the highway and the temp dropped back to 190.
Obnoxus- Posts : 5
Re: Running HOT
sounds like you may not have enough fan. i run a spal fan number IX-30102052 and built another shroud to seal it to the entire core. runs cool with my 572
mlp911- Posts : 23
» Anyone out there running a 498?
» Greetings from Edmonton, AB
» Anyone here running a EXP??
» Burned direct (third) clutchs on my c6
» Pro-filer Heads ?
» Pro-filer Heads ?
