5.8 Cam Wanted
5.8 Cam Wanted
anyone have a stock/factory roller cam for a 5.8 they wanna sell?
plowboy34- Posts : 223
Re: 5.8 Cam Wanted
plowboy34 wrote:anyone have a stock/factory roller cam for a 5.8 they wanna sell?
It is the same camshaft that an Explorer 5.0 engine has.
Ford Motor Company part number = F4TE-6250-BA
Re: 5.8 Cam Wanted
Thanks Randy I did not know that. That will make one easier to find
Re: 5.8 Cam Wanted
A 5.0 HO cam is a nice mini upgrade.
gt350hr- Posts : 662
Re: 5.8 Cam Wanted
gt350hr wrote: A 5.0 HO cam is a nice mini upgrade.
Yes it is ... and works well with O.E.M. valve train parts.
An 85 H.O. camshaft is slightly different than other later year H.O. cams.
85 H.O cam = 266/266 @S.A.E - .278"/.278" lobe lift - 115 separation; 115 intake lobe centerline
86 & later cams = 276/266 @S.A.E. - .278"/.278" lobe lift - 115.5 separation; 116 intake lobe centerline.
Ford Engineering extended the duration on the intake side slightly to help meet NOX emission standards of the day while using a 1/2 point more compression ratio with the masked, heart shaped chambers of the E6SE heads. For later years, they went back to the earlier type heads but, kept the H.O. cam profile changes.
Re: 5.8 Cam Wanted
I got one if you still need one .
whitefield- Posts : 2244
Re: 5.8 Cam Wanted
Well let me ask you guys this. I am rebuilding a 351W for my truck to pull a trailer. I do not care about high RPM all I want is low end torque. It is a speed density system and I am going to have GT40 heads with long tube headers. What would you recommend, I was planning on a stock roller with 1.7 roller rockers for a little more lift.
How much you want for yours whitefield
Re: 5.8 Cam Wanted
plowboy34 wrote:Well let me ask you guys this. I am rebuilding a 351W for my truck to pull a trailer. I do not care about high RPM all I want is low end torque. It is a speed density system and I am going to have GT40 heads with long tube headers. What would you recommend, I was planning on a stock roller with 1.7 roller rockers for a little more lift.
Free !
» how about a wanted section, we need one,please?
» Just wanted to say THANKS........
» *Wanted* Top end for 514
» Wanted Wanted Wanted
» wanted ,,, b&g
» wanted ,,, b&g
