What plug gap on my 15:1 , 600ci N/a and nitrous?
rocketpony
What plug gap on my 15:1 , 600ci N/a and nitrous? Empty What plug gap on my 15:1 , 600ci N/a and nitrous?
Post  rocketpony August 23rd 2016, 1:36 pm
I'm gona run ngk 10 on motor and 11 on nitrous (200-300hp shot).
So what should I gap my 10's at while on motor? And what should I gap my 11's at on nitrous?
Motor is 600ci, 15:1
C460 heads and intake
Single 1475 carb
Q16 fuel
Cam 289/308 .873/.840 and 114lsa
Used in a 1/4 mile car, no street use
rocketpony
What plug gap on my 15:1 , 600ci N/a and nitrous? Empty Re: What plug gap on my 15:1 , 600ci N/a and nitrous?
Post  richter69 August 23rd 2016, 2:26 pm
I run um out of the box, verify there is some daylight between the electrode and strap, proper heat range ... And in they go.....
Post  Frank Merkl August 23rd 2016, 2:44 pm
.025" N/A
.022" Nitrous
Post  rocketpony August 23rd 2016, 4:05 pm
Thanks guys!!
rocketpony
Post  richter69 August 23rd 2016, 4:22 pm
They are gonna be real close to .022 out of the box fwiw
Post  richter69 August 23rd 2016, 4:23 pm
Careful w that combo on nitrous.
Post  rocketpony August 23rd 2016, 7:08 pm
richter69 wrote:Careful w that combo on nitrous.
Why is that?
rocketpony
Post  rmcomprandy August 23rd 2016, 8:44 pm
There is no "magic bullet" here.
The ignition system's other components will have a giant affect upon what the maximum spark plug gap can be.
Use the gap which goes the fastest for that particular situation.
Post  rocketpony August 23rd 2016, 11:41 pm
What would b a good starting point with timing? I'm thinking 32
rocketpony
Post  Hardy August 23rd 2016, 11:46 pm
im thinking he's saying that because the 15:1 compression and the 114 lsa will make the tuning window very tight on nitrous. Not sure if q16 works the best with nitrous as well. But I don't know shit, so hopefully he'll be back to ckarify
Hardy
Post  Hardy August 23rd 2016, 11:49 pm
rocketpony wrote:What would b a good starting point with timing? I'm thinking 32
Fwiw my dads 601 c head deal is happy at 31.5*. Every engine is different, but I'd say 30-32 is a safe starting point
Hardy
Post  Frank Merkl August 24th 2016, 1:05 am
on motor! on the juice she's a whole new ball game !! 400hp no more than 12* 1000hp - 4* total !
Post  Hardy August 24th 2016, 1:18 am
Oh god ya lol. I just figured when he said starting point he was talking motor only
Hardy
Post  rocketpony August 24th 2016, 5:34 am
That's correct, I was referring to on motor
rocketpony
Post  tbirdmike August 24th 2016, 1:15 pm
Hardy wrote:im thinking he's saying that because the 15:1 compression and the 114 lsa will make the tuning window very tight on nitrous.  Not sure if q16 works the best with nitrous as well.  But I don't know shit, so hopefully he'll be back to ckarify
No direct experience from me.
From the Nitrous forums I follow (and several of the top Nitrous tuners and kit builders) q16 will make NOS tuning very difficult. And if that head has a tight quench it will add to the problem.
tbirdmike
Post  rocketpony August 24th 2016, 2:06 pm
Well that's unfortunate. Guess better use small shots of nitrous for now
rocketpony
Post  richter69 August 24th 2016, 2:50 pm
Its the q16 thats the issue w a combo thats already timing sensitive... Dump some C23 in and your parts will thank you.
Post  richter69 August 24th 2016, 2:53 pm
What is the quench?
Post  whatbumper August 24th 2016, 4:00 pm
There is nothing wrong with Q when you have a handle on what your motor needs but like said above start with a nitrous fuel first and figure out the combination. Q takes less timing than say C23 or NO2. NO2 is a great fuel as well. We have been spraying over 3000pph on a customers car all year with it on a "timing sensitive" SR20 headed deal.
Frank M above is pretty good at the timing on that head I would say. I've never had a customer spray that head but do have some chevy guys spraying 3000-4000 pph on some pretty tight chambers but with a huge quench. One efi customer for example we launch at -12° ramp that to 4° in first gear and pull it back down to 1-2° in high gear.
Post  Frank Merkl August 25th 2016, 1:50 am
get a new cam ! duration is about right , add .050 to the lift . and 117lsa min 119lsa better
or your going to have this
URL=https://s58.photobucket.com/user/fmerkl/media/20150815_162342_zpsroffali4.jpg.html]What plug gap on my 15:1 , 600ci N/a and nitrous? 20150815_162342_zpsroffali4[/URL]
1/2 degree  to much for .2 of a second as we had ramp the timing retard slower! I'm learning from the $50k worth of melted aluminum I have and the 24/7 hours it takes to fix it ! but we still put the toes over the edge every Run !!!! DAWM DRAG RACING IS FUN!!!!!
Post  rocketpony August 25th 2016, 1:59 am
Wow!
I guess il just use 150-175 hp jetting to start and tune it from there
rocketpony
Post  Frank Merkl August 25th 2016, 2:02 am
PS that run was still a 7.17@ 196 MPH on a 7.18 Dial and we lost the piston @ 4.78 seconds into the run ! ,and yes we won the round semi's for a wally !! Still did our 330 ft burnout to the 330 clocks for the final ( no lifters or pushrods in that hole or spark plug and the nozzles with blank jets) The Kid went RED on the launch and we were a brides maid again! 3 years ago!!
Post  Frank Merkl August 25th 2016, 2:13 am
I built that car 20 years ago !! myself ! with a 7 year old boy watching !! He drives it now as he spend 8 years in Jr Dragster , No delay box in the car and he can cut constant .004's- .020's , throw an odd red one in , then there will be also a .400 as the other guy red lights !! but HE's a Real Driver !!
Post  rocketpony August 25th 2016, 4:53 pm
Frank Merkl wrote:get a new cam ! duration is about right , add .050 to the lift . and 117lsa min 119lsa better
How much were u spraying at the time?
I guess if I keep the shot rely small and only activate for short period I should b ok
rocketpony
Post  Frank Merkl August 25th 2016, 6:13 pm
3000 pph
