460 Stroker Kits
+6
DaveMcLain
Mark O'Neal
10 posters
460 Stroker Kits Empty 460 Stroker Kits
Post  Mark O'Neal October 31st 2016, 9:15 pm
I am putting together a new line of stoker kits, stock heads and P-51.
I know Scat has a 4.750 stoke crankshaft for these things and my question is; Do people use these, or is it an outlier?
While I'm at it, what's the Blue Thunder head market like nowadays?
Mark O'Neal
460 Stroker Kits Empty Re: 460 Stroker Kits
Post  Lem Evans October 31st 2016, 10:35 pm
I'm unaware of the Scat 4-3/4 deal.....but Callies sells all they produce.
Post  68formalGT October 31st 2016, 10:37 pm
They had the 4.750 listed in their catalog but not much talk about it here.
Post  Mark O'Neal November 1st 2016, 3:41 am
Lem Evans wrote:I'm unaware of the Scat 4-3/4 deal.....but Callies sells all they produce.
That does mean that Scat will.
Are they mostly in boats, pullers?
Mark O'Neal
Post  dfree383 November 1st 2016, 8:15 am
Yes offer all strokes avaliable especially 4.5 and 4.75 if avaliable
Offer Pistons for Stock, P51/SCJ, AFR, A460 and C460 if you want to hit the major market
Post  Lem Evans November 1st 2016, 10:15 am
Drag cars mostly and some dirt/mud deals. Not many classes where pullers are allowed super huge engines but there are a few out there.
Post  Lem Evans November 1st 2016, 10:29 am
68formalGT wrote:They had the 4.750 listed in their catalog but not much talk about it here.
I guess they were trying to keep it a secret Smile They haven't sent me a catalog in about 5 years.
Post  68formalGT November 1st 2016, 11:59 am
Post  DaveMcLain November 1st 2016, 1:16 pm
With a 4.750 stroke aren't you limited to about a 6.700 rod length? With that consideration how well will this work in a production block except for the D9TE? Would you make pistons with bore sizes of 4.390, 4.440 etc or would you start with a 4.500 strictly with the SVO style block in mind?
DaveMcLain
Post  Lem Evans November 1st 2016, 5:45 pm
Most all are 6.7". A guy could get a 6.800" rod in there with a ~ 10.320" deck and 043/043/3mm. I'd want the longer cyl. and 4 both caps with either rod.
Post  Mark O'Neal November 2nd 2016, 2:42 am
dfree383 wrote:Yes offer all strokes avaliable especially 4.5 and 4.75 if avaliable
You have to offer what volume will support, unless you do it with a custom or "pre-engineered" piston, which I have no objection to.
Doing the kits with a stock and Kaase valve reliefs gets you 60 part numbers to shelf.
Of course most of the pistons companies don't stock but a fraction of their part numbers anymore. Maybe I should have gone to that model.
But I will add the 4.750.
Mark O'Neal
Post  Mark O'Neal November 2nd 2016, 2:57 am
DaveMcLain wrote:With a 4.750 stroke aren't you limited to about a 6.700 rod length?  With that consideration how well will this work in a production block except for the D9TE?  Would you make pistons with bore sizes of 4.390, 4.440 etc or would you start with a 4.500 strictly with the SVO style block in mind?
The bigger the bore is, the more you can pull the top land up. So I vote for a 6.000 bore with a 4.750 stroke and a 6.800 rod.... Very Happy
Using Lems parameters and the C/H is 1.145 which is doable and, if you can run a .975 pin you could get a land stack of somewhere around .320/.140/.078.
That's not too scary, though I'd like to find another .040 for the second land.
Or we could all stick with a 6.700 rod in that combination. Although I try to run the longer rods.
Mark O'Neal
Post  DaveMcLain November 2nd 2016, 7:54 am
I just wonder about getting it to work at BDC with the 6.700 4.750 stroke combo in the production block with its .250 shorter bore. D9TE blocks have a longer bore more like the SVO. 4.500 6.700 is very workable but here we're talking about pulling it down another .125.
DaveMcLain
Post  rmcomprandy November 2nd 2016, 11:55 am
I have used a 4.750" stroke in a number of Big Block Ford engines meant for some kind of racing; (not some low compression engine).
If that customer won't use an A460 block or other good option, then I simply say NO.
A 6.800" length rod works OK but, the 1.135" compression height does not allow for a dish of very much volume.
Post  gt350hr November 2nd 2016, 1:26 pm
A 4.750 crank and an early (pre D9TE OR SVO) block are a poor combination. The PIN is almost half way out of the bottom of the cylinder. That really loads the cylinder and the piston skirt beyond their limits. The piston skirts actually chaffe material off as they head up to the top due to the extreme loading and the D9TE/SVO blocks are only slightly better , still no adequate. Well over .600 of the skirt comes out the bottom on a short skirt design. The 632 Ford is better design wise over the Chevy because the .100 taller block does allow the 6.800 rod to be used but the bottom of the bore condition is still there. The longer cylinders require crank manufacturers to keep the counterweight shorter making it harder to remain internally balanced on steel rod applications.
A tall deck is a MUST for any stroke over 4.750 ( in case you didn't already know).
gt350hr
Post  BBFTorino November 3rd 2016, 2:56 am
I seem to recall a guy who was building a 4.750 stroke with a 7.00" rod and custom made 2 ring pistons. I think it was on the "other" 460 forum....the one I don't go to anymore because of the ridiculous advertisements
Post  gt350hr November 3rd 2016, 5:39 pm
I guarantee it will be an oil burner even with 20"s of vacuum in the crankcase.
gt350hr
Post  68formalGT November 3rd 2016, 6:51 pm
rmcomprandy wrote:I have used a 4.750" stroke in a number of Big Block Ford engines meant for some kind of racing; (not some low compression engine).
Randy, how does the Eliminator block compare to the A460 when it comes to the cylinder legenth and using a 4.750 stroke crank?
Post  dfree383 November 3rd 2016, 7:30 pm
gt350hr wrote:    I guarantee it will be an oil burner even with 20"s of vacuum in the crankcase.
They sure seem to work just fine
Post  Darrin Gorham November 3rd 2016, 7:47 pm
The 632 I had had 6.835 rods and 080 thick head gaskets
Darrin Gorham
Post  Mark O'Neal November 3rd 2016, 8:44 pm
gt350hr wrote:      A 4.750 crank and an early (pre D9TE OR SVO) block are a poor combination. The PIN is almost half way out of the bottom of the cylinder. That really loads the cylinder and the piston skirt beyond their limits. The piston skirts actually chaffe material off as they head up to the top due to the extreme loading and the D9TE/SVO blocks are only slightly better , still no adequate. Well over .600 of the skirt comes out the bottom on a short skirt design. The 632 Ford is better design wise over the Chevy because the .100 taller block does allow the 6.800 rod to be used but the bottom of the bore condition is still there. The longer cylinders require crank manufacturers to keep the counterweight shorter making it harder to remain internally balanced on steel rod applications.
There are some horrible combinations out there these days. 4.000 stroke Clevelands with 6.000 rods.
You have to weld a ring compressor to the bottom of the cylinder to make them work. This thing doesn't sound much different.
And everyone knows....if you have to weld it, it's no longer a "bolt-on".
Mark O'Neal
Post  mach1charlie November 16th 2016, 10:12 am
How about offering a 4.625 stroker for use in a D9 block? .060 over, please.
mach1charlie
Post  rmcomprandy November 16th 2016, 10:22 am
mach1charlie wrote:How about offering a 4.625 stroker for use in a D9 block? .060 over, please.
I think there is a 4.600" stroke cast steel crankshaft offered out there by someone.
I had a few Ford Racing, (big journal), 4.300" stroke, cast cranks offset ground to 4.600" stroke, also.
Post  gt350hr November 16th 2016, 3:56 pm
Two ring pistons have been tried at the highest levels and poor oil control is always the problem.
gt350hr
Post  dfree383 November 16th 2016, 4:37 pm
Not the case in the ones I know of, quite a few of them running in the east with thin 3 ring packs and nothing exotic or weird done to them or oil consumption issues that any one have expressed concern over. Keeping in mind these are not street motors.
