Jet size starting point
Could someone give me a good starting point for jet sizes on a Quick fuel fx-4712 1250cfm on a 557. 14-1 compression, ported A-429's, victor 460 intake and .785 int/.761exh 276/287 @.050. All out mud racing 2 1/8 open headers.
mudtrucker- Posts : 160
Re: Jet size starting point
Gasoline??...I'd probably start with 88's and go from there. Or call QF tech line and get their recommendation.
BBFTorino- Posts : 999
https://www.holley.com/products/fuel_systems/carburetors/quick_fuel/drag_race/qfx_series/parts/FX-4712
Stock is 94 no power valves. Hit SPECS on the link and you can see the factory settings.
supervel45- Posts : 4499
Thanks guys!
supervel45 wrote:https://www.holley.com/products/fuel_systems/carburetors/quick_fuel/drag_race/qfx_series/parts/FX-4712
YES ... starting with the jets which came in it, would be a preferred starting place.
What fuel are you planning to run?
FORDMUD- Posts : 290
» Slow cranking, popping at idle and high rpms
» Starting point for 4 link,
» What is good starting point for timing curve on heavy 4X4?
» Good jet & air bleed starting point for 8896-3 1050 dommy
» tire size to gear size
