466ci Ford Engine with Trick Flow Heads
Engine has only 10 1/8-mile passes on it. See photos here: https://www.racingjunk.com/8-Cylinder/182981450/466ci-Ford-Engine-with-Trick-Flow-Heads.html#1.
- Block – Ford casting number C9VE-B; line honed with torque plates and decked; bored 0.030” over; has head studs and new cam bearings; Melling M84DHV oil pump; steel Moroso Fox Body oil pan; Ford Motorsports timing gear and chain; cast upper gear; balanced and blueprinted
- Heads – Trick Flow street; ported, polished, and flowed by Charlie Evans; roller rockers with poly-locks; 2.200”/1.960” stainless steel valves; flow sheet provided
- Rotating Assembly – standard crankshaft; truck/cobra jet rods with ARP bolts; Speed Pro LW2443F pistons; 0.440” piston dome with 0.200” milled off; approx. 11:1 CR
- Camshaft – Comp Cams flat-tappet; 0.649” intake lift and 0.642” exhaust lift; 0.270/0.276 duration at 0.050”; EDM lifters; Trend 3/8” 0.135”-wall pushrods
- Other – Victor 4500 intake; MSD distributor; SFI harmonic balancer; SFI flexplate; freshly rebuilt water pump; Ford Motorsports valve covers; Fel-Pro gaskets
» 466ci Ford Engine with TF Heads - Still Available!
» Trick Flow A460 360cc heads cnc flow numbers
» C&C 325 trick flow heads
» Trick Flow Heads
» New Trick Flow heads for the FE
» Trick Flow Heads
