2017 F250
Bill Heard
2017 F250
I just bought a used 4X4 17 F250, man this thing is tall. I would like to lower it some what. Has anybody done anything with these newer trucks?
Bill Heard
Bill Heard
Bill Heard- Posts : 115
Re: 2017 F250
I have one and they are ridiculously tall. Like I am going to go mud bogging in my $70k truck. Everywhere I go I look at 2016 and earlier and they sit a lot lower so it sure makes me wonder WTF was Ford thinking?
jasonf- BBF CONTRIBUTOR
Re: 2017 F250
You guys are getting old....
Re: 2017 F250
dfree383 wrote:You guys are getting old....
Hell I had to re-learn how to get into this thing it is so high. Probably 4-6" higher then my last superduty. I imagine I will wear out the drivers seat in half the time now. lol.
Re: 2017 F250
http://www.powerstroke.org/forum/suspension-steering/1199697-lowering-rear-2017-f250.html
Re: 2017 F250
jasonf wrote:dfree383 wrote:You guys are getting old....
I’m guessing they finally put some real springs in them.
I had to add springs to my 12 to keep it from dragging ass when towing
Re: 2017 F250
The ass is all jacked up in the air like my 03 F350 is. I think it will be great pulling a trailer but I hardly every do that.
Re: 2017 F250
I have found out that my truck has a leveling kit on it.........front raised I think......... now I need to lower the front and back. I think I'm a little on the old side too.....
Re: 2017 F250
Last year I was at a Ford dealer and took these pics.
16 vs. 17
Both have the same FX4 package.
I did not measure but the '17 appeared to be 2 inches taller.
Yes, the new ones stand tall
16 vs. 17
83-88T-Bird Guy- Posts : 1003
Re: 2017 F250
Bill Heard wrote:I have found out that my truck has a leveling kit on it.........front raised I think......... now I need to lower the front and back. I think I'm a little on the old side too.....
I recently bought a 2011 F150 4x4.
Ford added a 1 1/4 inch block in the rear under the springs on the 4wd models vs. the 2wd..
I am going to remove those blocks the help level the truck out.
Not sure how thick your blocks are on your '17 tho
Re: 2017 F250
My 17 has a 3" block, the guy that had it first must have raise the front. I will hook up my trailer first and I will lower the whole truck later. thanks for the pics.
Re: 2017 F250
Went to Sacramento and back last weekend, amazing power, but disappointed with fuel mileage. Got exactly the same as my 22 year old 7.3 with 450,000 miles.
Re: 2017 F250
Mine is still new but I am getting 15... at 80 mph. My 7.3 was similar till it broke in. Then I added a DP tuner and I get 18-19 now... at 80.
Re: 2017 F250
Mine is new also, only had 4300 miles. I was towing race car. At 70 got 10 mpg, and at 60 just under 12mpg. With this 6.7 ..... there are no more mountains or hills.....
Re: 2017 F250
2017 F350 Dually CC 4x4, 3500 miles on mine. 12.5 mpg empty @ 75mph. Loaded with backhoe, 31,000 lbs - 7.5mpg @ 65 mph. No problems what so ever on hills.
Curt- Posts : 2791
Re: 2017 F250
my 05 didn't ride decent unless it had 3000# of rocks in the bed! Hauled 2 pallets of wet sod on it without a problem.dfree383 wrote:jasonf wrote:dfree383 wrote:You guys are getting old....
Re: 2017 F250
Update......I took the leveling kit, 2" spacer, out from under the front spring. Went to Oregon Auto Spring and had them remove the 3" block and install a 1" block. They made new U Bolts and installed all in about one hour. Less than $200. Now the running boards are just 1" higher than my old 2 wheel drive running boards and the wifes expeditions running boards.
» PRI Indy 2017
» 2017 6.7 Cummins 4x4 auto
» 97 460 F250
» Can anything be done to hop up a 5.4 in a F250?
» 97 F250 PSD help
» 97 460 F250
» 97 F250 PSD help
