466ci Ford Engine with TF Heads - Still Available!
466ci Ford Engine with TF Heads - Still Available! Empty 466ci Ford Engine with TF Heads - Still Available!
Post  KristinaLawyer February 15th 2018, 6:50 pm
Guys and gals,
We still have this great little engine sitting in the garage! Someone make us an offer so we can go racing this summer and you can go racing this summer.   Very Happy
https://www.racingjunk.com/8-Cylinder/182981450/466ci-Ford-Engine-with-Trick-Flow-Heads.html#4
  • Block – Ford casting number C9VE-B; line honed with torque plates and decked; bored 0.030” over; has head studs and new cam bearings; Melling M84DHV oil pump; steel Moroso Fox Body oil pan; Ford Motorsports timing gear and chain; cast upper gear; balanced and blueprinted
  • Heads – Trick Flow street; ported, polished, and flowed by Charlie Evans; roller rockers with poly-locks; 2.200”/1.960” stainless steel valves; flow sheet provided
  • Rotating Assembly – standard crankshaft; truck/cobra jet rods with ARP bolts; Speed Pro LW2443F pistons; 0.440” piston dome with 0.200” milled off; approx. 11:1 CR
  • Camshaft – Comp Cams flat-tappet; 0.649” intake lift and 0.642” exhaust lift; 0.270/0.276 duration at 0.050”; EDM lifters; Trend 3/8” 0.135”-wall pushrods
  • Other – Victor 4500 intake; MSD distributor; SFI harmonic balancer; SFI flexplate; freshly rebuilt water pump; Ford Motorsports valve covers; Fel-Pro gaskets
KristinaLawyer
http://www.LawyerMotorsports.com
