Plugs
Plugs
Hey Fellas.. Should be firing up my stroker 408 Cleveland in a few weeks. It is 12.7 to 1 compression. N.A. application. Plug recommendations?
Thanks!
Thanks!
747JetMech- Posts : 272
Re: Plugs
747JetMech wrote:Hey Fellas.. Should be firing up my stroker 408 Cleveland in a few weeks. It is 12.7 to 1 compression. N.A. application. Plug recommendations?
Thanks!
What plug thread dimensions and seating type does that head you are using require...?
Good Grief
Randy. With all the different heads out there, I didn't specify what head. Scatter brained to say the least.. OEM 4V Cleveland..
PS: I will post the numbers after it hits the dyno. Getting excited! ( 2 years! )
Re: Plugs
NGK UR4 or UR6 (colder)
FalconEh- Posts : 1448
Re: Plugs
747JetMech wrote:Randy. With all the different heads out there, I didn't specify what head. Scatter brained to say the least.. OEM 4V Cleveland..
With that compression ratio, I would use an Autolite AR23; an AR133 if there is a big dome on the piston.
Thx
Thank You...
Last edited by 747JetMech on May 24th 2018, 6:52 am; edited 1 time in total (Reason for editing : .)
» Leaking oil gallery plug
» Hot Champion plugs
» Plugs for a 428 FE
» SPARK PLUG RECOMMENDATION FOR SCJ-A ALUMINUM HEADS
» SBF E85 Plugs...?
» SBF E85 Plugs...?
