Need 4340 or 300M Input shaft for C6?
Gregaust
norm
Fordaholic495
Need 4340 or 300M Input shaft for C6? Empty Need 4340 or 300M Input shaft for C6?
Post  Fordaholic495 June 21st 2018, 2:22 pm
78 bronco, 4700-5000 lbs, 300 ft sand drag truck/occasional street driver, getting a 552 BBF with something like 700hp and 725+ ft/lbs. Needs to hold up to a trans brake, even though most of the time I will be foot braking it.
Is an upgraded input shaft necessary here and if so, where do you guys get yours from? Will obviously be real easy to do when I have everything out.
Fordaholic495
Need 4340 or 300M Input shaft for C6? Empty Re: Need 4340 or 300M Input shaft for C6?
Post  norm June 21st 2018, 7:25 pm
I ran a stock one for a long time and never broke one, 5000lbs with a brake, A head 598.
Last time trans was freshened we put a good one in for piece of mind but i don't recall the brand.
PM J.Toney on here and he can tell you what brand, probably any of the aftermarket ones will do the trick.
norm
norm
Post  Gregaust June 22nd 2018, 5:15 am
Frank suggests over 800 ftlb to upgrade . I've used a few TCI ones been ok
Gregaust
Post  Fordaholic495 June 22nd 2018, 6:41 am
Damn these c6’s are pretty tough! I’ll leave it alone for now, thanks guys!
Fordaholic495
Post  Gregaust June 23rd 2018, 2:43 am
Fordaholic495 wrote:Damn these c6’s are pretty tough! I’ll leave it alone for now, thanks guys!
I'm guessing on sand ? traction is limited ? I'd say the stock input will do ok:)
Gregaust
Post  norm June 23rd 2018, 8:57 am
Paddle tires hook up better than you would think but for the most part yes, just spinning.
norm
norm
Need 4340 or 300M Input shaft for C6? Empty ATI
Post  manofmerc June 28th 2018, 5:15 am
I bought one from ati you have to call them it isn't in the catalog it is the 300m material .The only broken c-6 input shaft I have seen was out of my 66 comet street car .Probably metal fatigue .Doug
manofmerc
Post  68formalGT June 28th 2018, 2:13 pm
I bought a 300m shafts from Broader. 3 years ago it was $175.
Post  Colt Macara July 8th 2019, 10:12 pm
PATC 300M C6 INPUT SHAFT
PA FROM SUMMIT C6 INPUT FROM SUMMIT
TCI TCI C6 INPUT SHAFT
HUGHES @ JEGS 4340 C6 INPUT
Last edited by Colt Macara on July 8th 2019, 10:40 pm; edited 2 times in total (Reason for editing : ADDED TCI SHAFT)
Colt Macara
Colt Macara
Post  J.Toney July 10th 2019, 8:19 am
NA or power adder? IMO, you'll probably get along fine with stock shaft at the NA level. But I might add it for a buffer if extra power shows up one day. I and Norm had gotten by with factory shafts in very similar apps for many seasons. Personal stuff was 521"/700h/650tq/5k with small plate kit, on transbrake, using smallish 17 paddle Hookers.
I will be upping power soon, and a upgrade shaft will be going in.
I've gotten them from Transtar, not sure who they use.  Norm's was a few years back, can't recall for sure where it was sourced.  All I've used seem to fit and hold well.  But prefer TCS Arizona if possible, TCS Canada is a great product also.
J.Toney
J.Toney
Post  Gregaust July 11th 2019, 4:21 am
Just remember also to check which you have . There are two types , a 31/31(early) & a 31/30 (later)
Converter ends are same , it's the forward drum end is different
Gregaust
