Compression with nitrous
Any suggestions on a safe compression ratio to run with kaase sr71 heads and a 400 shot of nitrous? Planning to build a 598. This is going to be primarily run on nitrous.
BBF552- Posts : 34
Re: Compression with nitrous
13.2-13.5 to 1
your results may vary
Frank Merkl- Posts : 1524
» how can i tell the compression
» Can you raise compression by changing rod length with same compression height?
» Compression help !
» compression ?
» Cam/Compression help on 472
» compression ?
