Fox body c4 transmission crossmember
I have always used my old t5 crossmember, but now the engine/transmission sit lower. The transmission has to be lifted for the crossmember to go in. I am afraid it would be too much pressure, although it seem to go back to natural resting level once mounted. The problem is it is solid mount to the crossmember to fit, no rubber/poly. The engine is on motorplates, so I need something that allows room for poly/rubber mounts.
Anyone have suggestions on a good aftermarket unit?
jpierce55- Posts : 111
Re: Fox body c4 transmission crossmember
Build some extenders to lower the crossmember accordingly.
BBFTorino- Posts : 999
I think I would get into exhaust clearance issues
I checked and may be able to do that...but the pass side mount for the xmember doesnt havr much materisl. Have you had success doing this?
they should just be L brackets spot welded to the floor pan, make some longer tabs and either double them up or remove the short ones and weld on the new ones
Mike R- Posts : 1381
I know where I can have some cut, I cant weld but can probably get someone over. Winter project in this regard. I need to repaint the underside.
The biggest part of the new alterations...the wife insists on ac....so we can enjoy it together.
Any opinion on the thickness of the rubber/poly mounts? I used to just use what is essentially a rubber pad. I am just not sure if I should try to go to a thicker poly mount? I need to check but the rubber pad guessing by memory might be .75" roughly.
jpierce55 wrote:I have always used my old t5 crossmember, but now the engine/transmission sit lower. The transmission has to be lifted for the crossmember to go in. I am afraid it would be too much pressure, although it seem to go back to natural resting level once mounted. The problem is it is solid mount to the crossmember to fit, no rubber/poly. The engine is on motorplates, so I need something that allows room for poly/rubber mounts.
I have used the t-5 cross member for years with my 460/c4 combo. The engine sits on solid mounts, the cross member is has been converted to a solid mount, and the transmission sits on a rubber mount. I also have to lift my transmission to get the cross member bolted in, then I can lower my transmission onto the cross member. I've never had any issues.
1982GT- Posts : 115
» AJE Fox body Powerglide trans crossmember.
» C6 transmission valve body question
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» Crossmember
» should I run a rear crossmember on my glide?
» Crossmember
