429 'Stock' Puller
95lightiningguy
THE WOOD
429 'Stock' Puller
I was hoping to get your guy's opinions on a few things regarding the build that I'm going to start. Project: Driver/Occasional Tow Vehicle (close distances)/Occasional 'Stock' Pulling Truck. Here's what I have: 1970 429 going in a 75 Ford Crew Cab 4x4. I plan on using the stock bottom end. I know compression is going to be a little high, but for how much, I'll most likely really end up driving this truck, I'll deal with it. BUT, I have considered swapping pistons to get compression around 9:1 or so. As far as the bottom end goes, I planned on upgrading the rod bolts to ARP and possibly installing a HV oil pump and a windage tray, besides that, I plan on leaving it as is. I planned on having some port work done to the heads and possibly installing larger valves. The heads will be matched to the Performer RPM intake that I have. Carburetor is an 850 Race Demon. Headers are 2" primaries, 4" collectors. To pull in the 'stock' class, the engine has to pull 16-17" of vaccuum at idle so I will need a cam to achieve this. One cam that has been recommended is the VooDoo 61602. I would like to try and get to a 500 hp level, max rpm around 6,000 rpm's. Not sure if that is possible, but?? So my questions:
Besides what I listed (rod bolts, HV oil pump and windage tray) is there anything else that I should do to this bottom end?? Would a HV oil pump even be necessary?? Would spending the money on pistons to drop compression be worth the gains when driving it down the road??
Would larger valves benefit this engine, or would port work be enough for this build??
What are your guys opinions on this cam?? Are there any other suggestions on a cam to achieve what I need on this build??
Any other suggestions you guys may have?? I'm open to them, however, I'm trying to keep this build relatively cheap, and I don't want the truck to turn into something that is no longer driveable down the road, but I would like it to perform nicely when on the track.
Thanks for your input/suggestions!!
THE WOOD- Posts : 11
Re: 429 'Stock' Puller
Not sure about everything else but I would find a 460 crankshaft, you can still use your rods and piston choices are alot better. Plus you get more cubes to play with. Just my 2 cents.
95lightiningguy- Posts : 570
I'd definately do the 3.85" crank and lose those heavy pistons. Yes port work on both sides of the heads will help a lot and make it more efficient to boot. Good luck Jamie, BTW I might go look at that ole CC in a day or two, I'l let you know. New paint on the puller is wicked cool.
schmitty- Posts : 4538
Thanks for the info guys!! I have access to a couple 460 cranks so that is definately an upgrade that I could do. As far as pistons go, does anyone have any recommendations on what piston would best benefit this build?? Any suggestions on a cam??
Cool!! Let me know on the cc, and pictures are always good:)!! Thanks for the compliment on the puller!! (I think it turned out pretty good for a couple of drunk Bohemians doing it!!)
If your going to lean on it I'd steer clear of the hypers and Cast Stuff, forged pistons are the way to go.
Well, I really don't plan on babying it by any means. Is there a specific piston that would work good with this build to keep compressions in the 9:1-10:1 range?? Assuming that the heads/block are not milled/plained?? Just trying to get an idea of pieces I may use before I start putting together a solid parts list.
Back to the cam......does anyone have an opinion on one or is the one that I have listed a good viable candidate??
Thanks for the help guys!!
I got a Weiand Stealth intake that could be had for cheep... Don't know what other stocker parts that I have but you know that you are welcome to them.
Speed pro makes a dished 460 piston that would work well for a reasonable $$ and Probe Pistons are a great bang for the buck also.
Even with a 460 you're not gonna get there.
In order to make your horsepower goal you'll need a camshaft which will be "to big" to get the required 16" of vaccuum with that low of a compression ratio.
Over 500 lb/ft of torque is entirely possible though.
I was kind of skeptical if 500 hp was achieveable with the limitations that I was putting on cam/compression. Torque is obviously good for what I'll be doing with it. Any guesses on what hp would be with the limitations I listed??
» Waking up a stock 5.0 roller engine - valvespring options while keeping stock retainers/rotators, etc...?
» U.S. Nationals Stock/Super Stock Qualifying Sheets
» looking for a set of used stock light blue injecters for my stock 460
» question about stock 1971 stock block
» Timing chain removal
