What starter with Jw bell 92454
What starter with Jw bell 92454 Empty What starter with Jw bell 92454
Post  Fast Fox February 9th 2010, 12:07 am
I have a Jw bell housing and currently have a Jw the whell 93001-x 164 tooth flywheel. Is there a certain starter that is needed with this bellhousing?
Fast Fox
Fast Fox
What starter with Jw bell 92454 Empty Re: What starter with Jw bell 92454
Post  bosshoss February 9th 2010, 2:37 am
I run the PG Ultrabell behind my 572 with a 93001 flex plate and have used everything from a stock starter to the csr mini with no problems. Must be an automatic starter and if you get the big block one with the threaded hole in the top you just drill out the threads.
dkp
bosshoss
bosshoss
Post  dfree383 February 10th 2010, 12:32 pm
Factory Ford 460 mini Truck (Late 80's to 90's) starter works great.
