crank spacer seal question
cobra501
I have the internal balance spacer,fits nice and snugg against timing gear. The outer surface is sealed by the timing cover front seal, what do I use between the spacer and crank surface. I was going to use RTV before installing it to make surre I have no leaks. Is this what you guys are doing.
cobra501- Posts : 95
Re: crank spacer seal question
Ok just seems like oil would find its way out from there but maybe I need to look at it again. Cant see it too good from Iraq. thanks
Thats why there's a seal in the front cover
cobra501 wrote:I have the internal balance spacer,fits nice and snugg against timing gear. The outer surface is sealed by the timing cover front seal, what do I use between the spacer and crank surface. I was going to use RTV before installing it to make surre I have no leaks. Is this what you guys are doing.
I understand what your asking,and these guys are right,nothing goes there,nothing needed,if you are worried about a oil leak there put a little silly cone behind the dampner washer,and dampner,but thats not needed there either
-rich
BOSS 429- Posts : 2372
Maybe never sieze they can be hard to get off after a while.Never had one leak oil.
had a balancer come loose once started leaking tightened it up went to next round
jts557- Posts : 56
» Crank spacer
» found some more + EVERYTHING IS SOLD
» spacer length behind balancer on crank snout ?
» Mr Gasket Ultra Seal Intake Gaskets Question
» crank to balancer spacer
