name this crank
name this crank
i'v got a crank i'm not sure about and thought i'd ask opinions.it does have ford on it and does'nt have the 3y,4u on it.it has D9TE6303BA on it and w31 on last c/wt.std.mains and 2.100 rods.4.250 sroke{somebody stamped it and it does check to be that}.what do yall think?
Re: name this crank
it's a factory Ford Commercial 429 Truck Crankshaft, and is a forged steel crank. It's made of 1046 or 1053 mild steel (not sure which one of the two). The OEM stroke is supposed to be 3.59" and if it has been stroked to 4.25/2.100 then the rod journals have been welded on in order to get that much stroke from it.
Paul
Paul
Re: name this crank
What do yall thank???
well what I thank is, is that , that crank is no good.
so you mite as well give it to me so it wont be in your way
res0rli9- BBF CONTRIBUTOR
Re: name this crank
well.........it checks out ok so i may use it for a spare. thanks for the offer. i was told it was a svo crank but did'nt know how to tell.the story was that it got hurt and was a 4.300.they had to go to 2.100/4.250 to fix it.what does a svo crank have on it in the way of casting #?thanksres0rli9 wrote:What do yall thank???
Re: name this crank
The SVO cranks from back in the day were made from a forging with the following part number: M-6303-B460 They are made with AMS-6415 4340 chromoly.
Got me one of them, too.
Paul
Paul
Re: name this crank
thanks for the info paul.i searched all over,even on your site but could'nt find anything like it.i guess it's kinda rare.
Blue Ovaless
I would donate it to the Blue Ovaless
511Fox- Posts : 251
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
» aluminum crank pulley and a crank trigger
» Crank advice needed
