Are N2O Cams Worth It?
Hey I have read in some of the mags about Blower cams and these seem to work but do N2O cams
Are these just fiction
How much improvement do they create
511Fox- Posts : 251
Re: Are N2O Cams Worth It?
Generally, cams that have more exhaust overlap and duration i might be wrong thou .... im sure the cam guru's will chime in and since cam selection depends largely on vehicle weight, gearing, etc., it is best to call someone like Lem Evans to discuss your entire build .... he will guide you in the right direction !! ....
If you are going to be spraying all the time then yes, you should consider a nitrous specific grind.
gryphon68- Posts : 51
usually if you stay at a 200 shot or lower you may not need a "nitrous" cam but if you are going to be spraying with the big dogs, a properly designed and ground nitrous cam will be beneficial.
whatbumper- Posts : 3024
» Comp cams thumpr cams.....
» COMP Cams 34-229-4 - COMP Cams Magnum Hydraulic Cam/Lifters
» How much is this 514 worth?
» What's it worth???
» What's it worth
» What's it worth
