autolite plug ?
nuclearcobra
autolite plug ? Empty autolite plug ?
Post  nuclearcobra Sun 28 Mar 2010 - 18:49
Is the AR3934's to hot for a 100 shot ? this is on my cobra 2 with a 86 stock short block 302 and the jegs/kaase heads with a comp 292 magnum flat hyd cam.
nuclearcobra
nuclearcobra
autolite plug ? Empty Re: autolite plug ?
Post  bruno Sun 28 Mar 2010 - 20:01
whats the compression ?
http://WWW.CKRME.COM
Post  Lem Evans Sun 28 Mar 2010 - 21:42
nuclearcobra wrote:Is the AR3934's to hot for a 100 shot ? this is on my cobra 2 with a 86 stock short block 302 and the jegs/kaase heads with a comp 292 magnum flat hyd cam.
Not in my opinion. When you start spraying more the 1st thing to do is reduce the ign. timing when the spray is on .
Post  whatbumper Sun 28 Mar 2010 - 21:52
we ran that exact plug with our 775hp (dynoed NA) sbf with victor heads hitting it with a 200 shot.
Post  studly Sun 28 Mar 2010 - 22:31
i personaly prefer the ngk's a little more forgiving if something is not quite right
studly
studly
Post  richter69 Sun 28 Mar 2010 - 22:34
Champion............... Laughing
Post  res0rli9 Sun 28 Mar 2010 - 22:56
champions ant shit gota get some ACs Twisted Evil
Post  whatbumper Sun 28 Mar 2010 - 23:25
studly wrote:i personaly prefer the ngk's a little more forgiving if something is not quite right
we run ngk's in our turbo car and our old motor in NA form but any time we sprayed it we had better luck with the autolites. we run the R5671A-10 in the turbo ride and we ran the -8 NA.
Post  nuclearcobra Mon 29 Mar 2010 - 7:26
bruno wrote:whats the compression ?
Its around 10.5to1 its a 86 shortblock from a lincoln Lsc and the factory heads had 69cc chambers and these kaase heads have 60cc. the pistons are flattops with no valves reliefs and a very slight dish to them. I did a compression test and it had 155lbs pressure and the cam is 244@.050-534 lift.
nuclearcobra
nuclearcobra
Post  nuclearcobra Mon 29 Mar 2010 - 7:58
Thanks guys i'll be spraying it this sunday hopeing for hi 10's, i bracket raced it for over 8 years with the spray a 150 shot was the most i tryed running 10.80's untill i brought the yellow 84 home from Missouri and stuffed a 472 in it and fell in love Very Happy and let the cobra 2 sit for over a year due to a cracked block then i put a new 306 motor toghether over a year ago got her fired up two weeks before thanksgiving and blew it to pieces a week before christmas from running it down the track with a ice cold oilpan and let it sit for another year then i took the kaase heads out of the spare bedroom i had new for 6 years now and put it on the last complete motor i had laying around.
nuclearcobra
nuclearcobra
Post  rddogoli Mon 29 Mar 2010 - 8:10
I run a 557ci with ported trickflow new style Aheads at 14.5:1 with 820lift roller with a AR3933 hitting around 175 shot.
rddogoli
rddogoli
Post  whatbumper Mon 29 Mar 2010 - 10:57
I guess I forgot to say that the R5671A-8 were the cross reference to the AR3934 plug. On NGK's the higher the number after the dash the colder the plug.
