Timing questions ?
Timing questions ? Empty Timing questions ?
Post  bruno March 31st 2010, 8:11 am
ok so here it goes ......
Msd 7531t, crank trigger, 2-stages etc.....
1- at what degree do i want to phase the dist. at if im im at 24* on the first stage ? and 20* on the 2nd ? do you want to just split the difference between the most timing you pull and your baseline ?
2-when i have my stages activated is it going to on the timing light ? what i mean is when im ting the motor and the balancer reads 32* as soon as i flip the switch to the 1st stage it should read 24* ...correct ?
thxs for the input guys
Nick
http://WWW.CKRME.COM
Timing questions ? Empty Re: Timing questions ?
Post  paulie9fingers April 1st 2010, 9:32 am
We always phase the distributor to the final timing point, if you're going to be running 20* when both systems are on then phase it at 20*. And yes on the timing, you should see the timing retard when each system activates, it's a little hard to see if they are coming on real close together so we change the timer to allow us time to see it happen.
Paul
paulie9fingers
paulie9fingers
Post  bruno April 1st 2010, 9:43 am
thank you Paul for the responce
