My 548 c-headed combo
mikep
Block: Eliminator Premier 4.600 bore with .904 bushed lifters and 60mm cam tunnel.
Crank: Scat billet lightened 4.125 stroke with stock mains and 2.100 rods
Rods: BME rods 6.650 long
Pistons: 4.600 JE domed coated skirts, gas ported and lightened ALOT!!. 16.4 to 1 comp.
Cam: 60mm Comp cams .940 lift and 280 @.050
Heads: Charlies C-460, manley ty valves and WW 1.8 rockers
Intake: Sheetmetal with 2 Prosystem 1150's
Lifters: Isky red zone with the easy roll option .904 diameter
Makes 1152hp N/A @ 8200rpm and 834 ftlbs @ 6200rpm
Used to make 1132hp N/A @ 8000rpm and 822 ftlbs @ 6000rpm
Runs 8.38 @ 164.44 in a 3200lbs 1985 mustang in 2800ft of air on a 29.5x10.5 slick
Should run a little better with the new found power!!
[img]URL=https://s441.photobucket.com/albums/qq133/prostock12/?action=view¤t=548003.jpg][/URL][/img]
mikep- Posts : 64
Re: My 548 c-headed combo
Thxs Mike for sharing your build ...... love the new scoop
Nice build Mike,sounds like a real SCREAMER
this combo might be for sale early next year after it is freshened up!
mikep- Posts : 64
Yeah it screams!! shift at 8600 and 9000 through the lights!!!!!!!!!!!!bbf-falcon wrote:Nice build Mike,sounds like a real SCREAMER
mikep- Posts : 64
Update!
Went 8.382 @164.95 in 4200 feet of air!
mikep- Posts : 64
mikep wrote:Update!
Mike,
That's mighty good at 4200 ft. Makes you wonder what it would do down at sea level air. I'm proud of ya', that's for sure! Keep up the good work
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
c.evans wrote:mikep wrote:Update!
Mike,
Uncle Charlie
I'm thinking high 7's, Charlie
Nevs- BBF CONTRIBUTOR
Thanks Charlie and Steve!
Unfortunately I had to sell the car as a roller and start all over again. They killed my class so I have to build a stock suspension car and run outlaw 8.5 or TT5. Outlaw 8.5 weight is 3150 N/A on the Hoosier 27" x 9" slick and TT5 weight is 2950 on a 29.5 x 10.5 and I get to spray it. Haven't decided on a class yet but i'm building the car for both. The car has already has gone 5.35 @ 132 mph in the 1/8 in that bad air @ 3200lbs. The record in TT5 is 4.87 so I do not know how close I can run to that 250lbs lighter and a 200 shot?? what do you guys think?
mikep- Posts : 64
mikep wrote:Thanks Charlie and Steve!
Mike,
At the 4.87 level, I honestly believe it is more about the suspension and getting great weight transfer, and getting the small tires to "hook". I believe you are making enough power, and it sounds like you'll be adding nitrous, so you'll have even more power. Will the 200 shot come from a plate system, or can you use foggers?
Charlie
I was planning on using plates if I decide to run TT5. I was going to leave on the motor and hit it 100ft out and see if it will hold it. I will probably run the outlaw 8.5 on the motor to get a handle on the new chassis for now. It will be interesting to dial in the car without the aid of a wheelie bar since it is not allowed in 8.5. The race director said he wanted to keep the 8.5 class around the 5.50-5.40 range but I doubt that will happen. That Hoosier tire actually 9" wide and 27" tall so I do not think the tire will be the limiting factor for me. It's probably going to be the stock suspension and no wheelie bar learning curve.
mikep- Posts : 64
Outlaw 8.5 at the valley use only MT 26 X 8.5's, not other tire is allowed. A low 6 second or high 5 second car used to be competitive a few years ago, but now they are getting into the 5.50's adn 5.40's
D. Sea- Posts : 2768
are you putting this in a fox body mustang and if you are where are you going to get the headers from?
bigjohn2007- BBF CONTRIBUTOR
The combo was already in a fox body so I already have headers.
mikep- Posts : 64
so did you have them custom done or did you order them from a co.
