Flowing a plate...
+6
jones
DFI429
cam2
nuclearcobra
Northwest outlaw
Induction-Solutions
10 posters
Flowing a plate...
Thought a few of you might find this info to be helpful...
http://www.induction-solutions.com/forums/showthread.php?t=682
Thanks, SJ
Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Re: Flowing a plate...
Cool deal Thank you for takeing the time and posting that up.
Northwest outlaw- Posts : 962
Well i feel better about my zex plate now thanks
nuclearcobra- BBF CONTRIBUTOR
WOW ...
Just saw this now... I've run some bigger shots on stock-bottom-end-motors with plate systems and this just set me back
I never took into consideration the balance in a plate setup, as they're usually lower HP setups, but it still matters..
Thanks a million Steve!
WOW that plate just looked all messed-up.
jones- Posts : 2230
You might want to check out this one too..
http://www.induction-solutions.com/forums/showthread.php?t=693
This is another type of plate we flowed and wasn't to impressed with the findings.. Thanks, SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
great findings Steve
So what plate out there now is the best for spray?
I'm just asking cause I'm thinking about a plate in the 125 shot range...
a big shot or and eldebrock plate i believe are about the best out there for the money. i think steve has his own that is close to dead on but it cost a little more
studly- Posts : 512
Maddmattmustangs wrote:I'm just asking cause I'm thinking about a plate in the 125 shot range...
come on now that is a baby shot. you need at least 82's. just kidding. we used a cheap ole cold fusion plate which was the class plate for 3 years with the 82's and never burned anything up after hundreds of passes in the 5.50's in a 3250lbs Fox with a sbf. we used square jetting and like 5 lbs of fuel pressure.
whatbumper- Posts : 3024
whatbumper wrote:Maddmattmustangs wrote:I'm just asking cause I'm thinking about a plate in the 125 shot range...
Lol I know 125 isn't much, I just want alittle extra if I'm not quite happy with the output. And I don't think I'm ready for a big hit yet
Maddmattmustangs wrote:whatbumper wrote:Maddmattmustangs wrote:I'm just asking cause I'm thinking about a plate in the 125 shot range...
you won't spray that little shot for long
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» flowing some big boy jets
» head flowing
» Cam thrust plate and water pump baking plate questions
» Best flowing standard BBF exhaust port
» head flowing
