NOS CAM HELP
studly
NOS CAM HELP Empty NOS CAM HELP
Post  studly June 21st 2010, 11:03 am
Can anyone point me in a direction for a good NOS cam for a 532 BBF with elde heads, the cam i currently have runs okay but it does not like to run until 6000rpm and then it takes off. i would like to move the curve down some as i have a stock dove block girdled.
Example
leave 3200rpm shift 6800 rpm at 3300lbs motor only car runs 6.60
leave 4200 rpm shift 7800 rpm at 3300lbs motor only car runs 6.40
studly
studly
NOS CAM HELP Empty Re: NOS CAM HELP
Post  bruno June 21st 2010, 11:30 am
Give Lem a call .......
http://WWW.CKRME.COM
Post  dfree383 June 21st 2010, 11:39 am
how much spray? what cam is in it now? whats the rest of the combo?
Post  studly June 21st 2010, 1:14 pm
intake .816
exhaust .780
duration @.050
in-284
ex-302
valve timing @.050
open close
in- 28 btdc 76 abdc
ex- 85 bbdc 37 atdc
lobe sep 114.0
Cam that is in it now
12.9 compression
4340 forged crank
4340 h beam rods Arp 200 bolts
Coated rod, main and cambearings
DSS Main Girdle
Dove block
Forged nos pistons
ported eldebrock victor heads
eldebrock victor 460 intake ported
Monte Smith Fogger
250-350 spray
studly
studly
Post  dfree383 June 21st 2010, 3:33 pm
you have something way out of wack, 3300# and only running mid 6's in the 1/8" with a 250-350??? Shot with 532"........
What the Trans, Convertor, Gearing, Tire Size, Ect.
Post  studly June 21st 2010, 3:48 pm
no 6.40 is on motor alone the car will run 5.65 @126 on a 250 hit but it does not feel like its making any power until over 6000 rpm i want the cam to have more bottom end and less top end rpm. the car has a good UCC 9.5 tight nitrous converter and 3.89 gears on a 28 x10.5 tire. it does the same on motor or nos does not feel like it has any power untill it is way up in the RPMS.
studly
studly
Post  dfree383 June 21st 2010, 4:12 pm
OK so it actually runs 5.65 @ 126 on no2 no matter where you shift it?
Is the Cam properly degreed in? and where do you have it installed?
Post  studly June 21st 2010, 4:34 pm
got a hold of LEM he is helping
studly
studly
Post  hayhauler June 21st 2010, 7:33 pm
please more info when you find out more im curious
hayhauler
Post  studly June 21st 2010, 7:48 pm
well basicly i have a very good cam just not enouph motor if it was a 570-598 a460 motor it would be spot on but since its an eldebrock headed 532 with not enoph compression it does not want to work unless i spin it then the heads give up right when its making power. going a whole different route. if you have a a460 headed motor with about 14.1 compression i have the cam for you on sale now. Laughing
studly
studly
Post  Barney June 21st 2010, 9:31 pm
studly wrote:well basicly i have a very good cam just not enouph motor if it was a 570-598 a460 motor it would be spot on but since its an eldebrock headed 532 with not enoph compression it does not want to work unless i spin it then the heads give up right when its making power. going a whole different route. if you have a a460 headed motor with about 14.1 compression i have the cam for you on sale now. Laughing
With spray it shouldnt matter, I only have 460 inches and on the sauce it hits hard as F@#K. Nitrous makes a ton of torque RIGHT NOW, so if its not moving down low something else is happening.
Barney
Barney
Post  studly June 22nd 2010, 9:30 am
We shall see i know nitrous makes power but how well it makes it is a combination. if the car stays the same after cam swap i will post up before and after et for same hit
studly
studly
Post  bruno June 22nd 2010, 10:03 am
Cool cant wait to see the before and after numbers Twisted Evil
Post  bruno June 29th 2010, 8:11 am
any updates ??
Post  studly June 29th 2010, 9:28 am
I got my new cam yesterday, taking it to the machine shop today to put the double key in it should have back by friday, but i still need to get a set of Rocker Arms going to take a little time to come up with that money. I am going to put the motor back together this weekend and save some coin for new rockers. i had the old style Crane with the pressed in bearings and one of them popped out and dropped the needle bearings in the motor just luckaly the screen was too small for them to go into the motor.
soon as i get them back to the track for some testing
studly
studly
Post  studly July 22nd 2010, 11:39 am
Well got cam in and new rockers on the car picked up almost 25-30psi of cranking compression, sounds good. testing Friday night cant go back to same track i tested before but will will see what happens
studly
studly
Post  bruno July 22nd 2010, 11:54 am
Twisted Evil .... cant wait to see the #'s
Post  bigjohn2007 August 15th 2010, 11:58 pm
what happen with the cam swap?
bigjohn2007
bigjohn2007
Post  studly August 16th 2010, 9:11 am
The car is making alot more power now, i am tring to work on the suspension the car is running about the same et but .60 is slower due to spinning and 330 is faster. trying to get the bugs out with the newfound power car is pulling now on the lowend .
studly
studly
Post  studly November 6th 2010, 7:55 pm
Well the cam swap finally worked out got the bugs out of the car and ran in the 40s on a 250 hit this pass Friday. Thanks LEM EVANS Very Happy
studly
studly
Post  Lem Evans November 7th 2010, 4:59 pm
Cool Very Happy
