horsepower chart opinion
+23
D. Sea
bb429power
prosandguy
TeflonDon
nuclearcobra
56Tbird
AZFairlane
Barney
Wayne Pearce
PROSTREET66
bosshoss
605FOX
95lightiningguy
ThndrChkn
Diggindeeper
wayne rhodes
27 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: horsepower chart opinion
I was checkng out your ride you race in coooooool95lightiningguy wrote:Not even gonna comment. Wain is thick headed. Okay so I commented, sue me.
wayne rhodes- Posts : 34
Huh?wayne rhodes wrote:I was checkng out your ride you race in coooooool95lightiningguy wrote:Not even gonna comment. Wain is thick headed. Okay so I commented, sue me.
95lightiningguy- Posts : 570
- Code:
HA! HA! what are you lonesome for attention or are you playing crazy You dah clownthe Coug wrote:Wayne if you cut the block deck down to 9.8 you will have no deck surface to bolt the heads to, if I remember corectly last block I checked the deck was only .430 tick and you want to cut .520 off....... you will have 8 cylinders sticking up with on support to bolt anything too......
- Code:
- Code:
- Code:
- Code:
- Code:
- Code:
the last one I built made little over 800 BHP the dyno could not hold it any lower than 4000 rpms thats when I was helping a friend tune a 557ci drag truck and did not have the time to build it till the season was over it had aluminum rods and JE dome pistons and a solid roller cam 713 lift full baffle pan Kaase p-51 heads good but not maxed on the porting.This engine will take longer to build because every piece will be inspected x ray-ed and zigloed for the aluminum can't spell it right have not made up my mind on the heads yet I was thinking blue thunder a's but so that is still up in the wind I know that I will be running an oval port intake port on the heads so the intake air will not peel of the floor and become turbulent like the first motor did not all cylinders mind you but on the dyno you could hear when it went turbulent and loose power we had to weld a streight bump in line weld down the intake to striation out the flowDiggindeeper wrote:how much powa is this neck snappin widowmaker gunna make?
lmao ....this guy is playing yall .....yall are getting punked
bruno,bruno are you a punk or are you a hard core racer if you are a man then act like one instead of a little kid Looks like you are al by yourself Waynebruno wrote:lmao ....this guy is playing yall .....yall are getting punked
wayne rhodes wrote:bruno,bruno are you a punk or are you a hard core racer if you are a man then act like one instead of a little kid Looks like you are al by yourself Waynebruno wrote:lmao ....this guy is playing yall .....yall are getting punked
Hardcore "yes" punk "no" ...why dont you bring your championship azz down to Montgomery this weekend and we can lock in a race !!! Im sure your trip from North bama wont take you that long ...... you can even use that short deck engine you got there as well .......
better
who is this guys wayne ???
605FOX- BBF CONTRIBUTOR
Hey Wayne... Bruno is not alone... I am with him 100%.
You are sure fun to have around. Keep up the good work.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Nick did you just tell Wain to bring his short dick??????????????????????????????
PROSTREET66- Posts : 245
Oh, PLEASE, PLEASE don't confuse this A$$HOLE with me!!
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
- Code:
- Code:
- Code:
ThndrChkn wrote:That's what I was questioning.
Doug old chap hows old yell-er running now days. and have you done anything to lighten the body up and set the motor back a few inches? My truck is a 1971 F-100 short bed and with a tilt over fiberglass front end hinged and pined and also a after market bed thats also fiber glass. aluminum wheel and drive shaft and back halved with mickey Thomson 15/15/30 slicks and adjustable control arms. and it weights 2950 with me in it. also a eight point roll cage with engine and rear tubular upper and rear frame rails. aluminum wheel wells with coil overs adjustable tilt bars electric everything, everything except the alternator that fits the fan belt so loose that it is hardly noticeable, on the hp curve 650+ BHP at 6200 rpm everything else is confidential now it is your turn to tell me about your truck? and oh it was a 550+ hp truck but we changed the cam to a comp solid roller cam kit and a weiand tunnel port intake with a duel carb top with duel 600 cfm tricked out Holley's. I wonted to run the truck at the digs but we got rained out. WR
Doug...
Randy the question was Compression ratio not deck height thats BBC deck height your saying we are talking static compression with a 10.300 to 10.330 deck big block ford. why am I not racing we got rained out at little river drag way.the Coug wrote:Wayne if you cut the block deck down to 9.8 you will have no deck surface to bolt the heads to, if I remember corectly last block I checked the deck was only .430 tick and you want to cut .520 off....... you will have 8 cylinders sticking up with on support to bolt anything too......
must be a big river now
res0rli9- BBF CONTRIBUTOR
- Code:
where do you keep coming up with a short deck block?? my block is a standard deck height 460 production block and with tricked out cast iron heads for some class runs and tricked out aluminum heads for the all out class with limited cubic inch class super stock, limited stock with a .060 over limit bore and 4.150 limit stroke class I run the 502 version with the 0.30 over bore and have had some great results. And but we got rained out down at little river drag way. I do not know which class you run in down in Montgomery, but I only race at my local track. Im not rich by any means. so I have to search high and low for my used race parts at swap meets and or people getting out of drag racing and selling out there car and engine parts. Yes I'm a scrounger for parts and but I win my share of the races also to put back in the truck. even had good luck in the open race run wotcha brung and got in the money there also.I did not win or get put n the trailer either.that class pays runner up if it is a couple tenths under the winner WR605FOX wrote:who is this guys wayne ???
what apened to you did you get rain out to or did you break that van you driveres0rli9 wrote:why am I not racing we got rained out at little river drag way
You and Jeremiah share a dictionary? Define great captain vague.wayne rhodes wrote:
- Code:
where do you keep coming up with a short deck block?? my block is a standard deck height 460 production block and with tricked out cast iron heads for some class runs and tricked out aluminum heads for the all out class with limited cubic inch class super stock, limited stock with a .060 over limit bore and 4.150 limit stroke class I run the 502 version with the 0.30 over bore and have had some great results. And but we got rained out down at little river drag way. I do not know which class you run in down in Montgomery, but I only race at my local track. Im not rich by any means. so I have to search high and low for my used race parts at swap meets and or people getting out of drag racing and selling out there car and engine parts. Yes I'm a scrounger for parts and but I win my share of the races also to put back in the truck. even had good luck in the open race whatcha brung and got in the money there also.605FOX wrote:who is this guys wayne ???
- Code:
[code][/code]
where are you? did you go to bed or what your van l@@ks like the o on pinks that wheeled all the way down the quarter mile track!!res0rli9 wrote:why am I not racing we got rained out at little river drag way
im to dam old to sleep!!...
gota keep you youg whipper-snapper's in line.
oh and it ant a van its a pick-em up truck...just dont know what to do with you dam young-in's
I'm 56 years old if thats young then so are you young at 60 that truck from the front l@@ks like a van that has been chopped off and made into a truck? again do you ever go drag racing with that truck!res0rli9 wrote:im to dam old to sleep!!...
its a 1961 Econoline pick up, made by FORD
no havent been drag racing with it or any kinda driveing
no lic. scence befor I got it built. 466 C6 narrow 9"
C/Os, L/B, full 2x3 frame
dose a good job of messing up the yard
its in the post a pic of your rides somewhere
bruno wrote:wayne rhodes wrote:bruno,bruno are you a punk or are you a hard core racer if you are a man then act like one instead of a little kid Looks like you are al by yourself Waynebruno wrote:lmao ....this guy is playing yall .....yall are getting punked
better
Funny, the only Little River Dragway I could find is in Holland Texas.
AZFairlane- BBF CONTRIBUTOR
Yall need to quit feeding the @#$%.
- Code:
- Code:
Lay off the jungle juice and get your license I am just a poor by with a small disability check once a month if im lucky my wife will let me save $40.00 a month for my truck. that I have been up grading for years now try about 24 years now and also have a 2 3/4 yer old baby girl to see to so but I keep trying t do my thing for my street rod and my race car if I can win it for the most part goes back into the car with race fuel going for $9.00 a gallon it is hard some times I wont to through up my hands and Quit and sell everything offres0rli9 wrote:that truck from the front l@@ks like a van that has been chopped off and made into a truck? again do you ever go drag racing with that truck!
no havent be drag racing with it or any kinda driveing
[/quote]Lay off the jungle juice and get your license I am just a poor by with a small disability check once a month if im lucky my wife will let me save $40.00 a month for my truck. that I have been up grading for years now try about 24 years now and also have a 2 3/4 yer old baby girl to see to so but I keep trying t do my thing for my street rod and my race car if I can win it for the most part goes back into the car with race fuel going for $9.00 a gallon it is hard some times I wont to through up my hands and Quit and sell everything off [/quote]
GFP RACING ?????????????
TravisRice- BBF CONTRIBUTOR
» BIG BLOCK FORD HORSEPOWER CHART INFO gathered by DJOHAGIN
» Cu In Chart
» times conversion chart.
» Displacement Chart
» HP chart questions
» Cu In Chart
Page 2 of 4
