Let the 466 mayhem begin...
+22
dirt_worker
1970 ford maverick
nuclearcobra
56Tbird
501ranger
Tony M
audietorino72
72mav
blown86hallet
lghting94
Maddmattmustangs
ThndrChkn
bb429power
26 posters
Page 2 of 7
Page 2 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: Let the 466 mayhem begin...
Didn't really work today, took the longest time to get the cylinders cleaned up. That's what's the hold up, I got 5 and 6 in. I went outside really late, I can't really do much though. Should I put my cam and chain on once I get the pistons in? I was just thinking about doing it so its done. I'll leave the lifters out of course.
bb429power- Posts : 3129
If it was me I would go ahead and finish the bottom end 1st with the oil pump,pick up tub and put the oil pan on temp.But you can go ahead and stick the cam in if you want but if you going th degree it in I would leave the chain off until then.
Jim
Jim
I'll leave the cam out then. Lets see, oil pump can go on, summit gave me the wrong pickup so its got to go back, oil pan needs to be painted but I don't have the green yet. I'll get the pump on and set the pan in place without a gasket for now for protection I guess.69F100 wrote:If it was me I would go ahead and finish the bottom end 1st with the oil pump,pick up tub and put the oil pan on temp.But you can go ahead and stick the cam in if you want but if you going th degree it in I would leave the chain off until then.
Jim
Wont hurt anything to put the cam and timing chain on you have to start somewhere to degree it so just set it straight up for your starting point at least that is what i would do
lghting94- Posts : 762
That's what I figured because the chain has to be on to degree it. But I'm just thinking in terms of the cam just sitting there with the break in lube on it, I don't think it will drip off though. I'll figure something out.lghting94 wrote:Wont hurt anything to put the cam and timing chain on you have to start somewhere to degree it so just set it straight up for your starting point at least that is what i would do
All the pistons are in, cylinders look clean.
Are you covering this with a big plastic bag when your not working on it? An oily block is a HUGE dust magnet!!
I use the big yard waste bags.
Sounds like it's coming together nicely for you. Be rumblin before you know it!!
Bill
Bill
billandlori- Posts : 2081
Thanks, I'm covering it with a big industrial trash bag. Cylinders get dust spots in it when I'm cleaning the other one's to get the pistons in. I don't know how much the dust will hurt it if I turn it over like that. Hope not too much.billandlori wrote:Are you covering this with a big plastic bag when your not working on it? An oily block is a HUGE dust magnet!!
Bill
You could run some green masking tape over the assembled cyl's, just need to make sure any oil is off the deck.
Your attention to detail will pay off!! Keep it up.
Bill
Bill
I was going to but all I have is duct tape right now. I might put that over it so it at least has something. I need to get a picture of it now. I got that painters eye, it comes in handy a lot of times.
One thing I noticed was that a couple of the main caps were hanging off the saddle about 1/16 of an inch and were flush on the other side. Is that normal?
Justin.
If you want to toss that "TRASH BAG" out, I have some great engine bags I get from work. Armor guard, super heavy plastic, with rust inhurtitor...
Just a thought, I have many, many, many bags!
blown86hallet- Posts : 1012
I'll have to ask my dad if I can stop by. Thanks for the offer, they sound pretty TOUGH!blown86hallet wrote:Justin.
Take your Dad with ya, and get him out of the house.
BTW, where is your cam?? That should always go in first. Then the crank wont interfere with you installing the cam.Also, that extra cap material wont hurt a thing. Its the centers alignment that matters.
72mav- Posts : 1081
Cam is very protected under my bed. I was going to wait so the lube isn't dripping off or gathering dust. I don't know, it wont hurt to wait until I am ready to put the rest of it together.
How would the crank interfere with the cam? I've changed out cams quite a few times and the crank never bothered it. The way I was told to center it was basically to rock the crank back and forth and tap the #3 cap with the hammer (plastic hammer) on the sides.
Looking good Justin, you will find alot of help from some great guy's on here like I did...
audietorino72- Posts : 49
Heads, valves, and springs are in. Heads are a little rusty and I guess I'm going to take them back then he will show me how to assemble them and check the tolerances. And I was JUST thinking "man if I had my heads I could get this thing together", then dad called and said he wanted me to get some stuff out of the truck. It was nice to see them again, but they seem like they're a little lighter Maybe I'm just so much stronger now from moving all the parts around in auto?
If you move very many bbf parts around like cranks,heads,blocks you want have to go to a gym for a work out
69F100 wrote:If you move very many bbf parts around like cranks,heads,blocks you want have to go to a gym for a work out
Don't get me started on the crank I took a look at the comp cams springs They be the gooood ones! Dual springs plus a damper, orange stripe (don't know what the different colors mean).
bb429power wrote:69F100 wrote:If you move very many bbf parts around like cranks,heads,blocks you want have to go to a gym for a work out
Lets not get started on te stripes
Idk how much a 429 shortblock weighs but I lifted one up and moved it about 10 feet
I should take some pics nextime I move it lol and me holding an empty cleveland block
Idk how much a 429 shortblock weighs but I lifted one up and moved it about 10 feet Shocked
YOU do know this post is NO GOOD with out pic's don't you.
res0rli9- BBF CONTRIBUTOR
I'll do what I can tomorrow between jobs
Well I am waiting to get a Jomar cam degree kit from Kaase then take my heads in and assemble them myself. I need some more stuff, to get the timing cover. Man I really want to get this thing going! Once I fire the engine up and its all broken in I will be fine. I just want to hear her purr.
what vehicle are you stuffing that baby in ?
Tony M- Posts : 479
Page 2 of 7
