Another Good Seller Alert
Another Good Seller Alert Empty Another Good Seller Alert
Post  Jaybob August 13th 2010, 5:07 pm
Adney Brown of Performance Crankshafts did an absolutely outstanding job providing me a modified forged 429 ford truck crank to suit my blown 429 engine... He also provided the necessary main and rod bearings as well. all for a reasonable price... You can't go wrong with Adney and Performance Crankshafts
Cheers,
-Jay
Jaybob
Another Good Seller Alert Empty Re: Another Good Seller Alert
Post  gafred99 August 15th 2010, 6:21 pm
how much was it all? what bearings? shortened the snout?
gafred99
Post  Jaybob August 16th 2010, 10:51 pm
Adney did a fantastic job. Basically he trued it all up, worked his magic on oiling, lightened the crank, turned the snout to a passenger card diameter, then finished the flywheel flange to passenger dimensions and pushed in a bushing for my Lenco... The snout he left long for me at my request so that I have ample place for blower pulleys and such. The bearings he set me up with are King High Performance...
All that and shipping for less than $1100...
I'll also say this, when I contacted him, he was a**hole-deep to a tall Indian in racing crank work. He asked me if I needed it soon and I said no rush. He told me that it would be a while and he never rushed the job just to get it done and paid for. He did what he needed to do, to make a good crank... Kudos to Adney...
Jaybob
Post  gafred99 August 17th 2010, 2:12 pm
do you run a 3" wide belt on a *\71?
gafred99
Post  Jaybob August 17th 2010, 2:26 pm
I'm still in the process of building this motor... I have an 8V71, (oldskool - ;-) ), style blower. I do plan to run a 3" timing belt drive on this. By the way, I'll drill bleed holes in the pulleys so that air can escape that wide-a**ed belt...
Cheers,
-Jay
Jaybob
Post  gafred99 August 17th 2010, 3:31 pm
Which way are you running the pulley by that I mean mounting face in or out?
gafred99
Post  Jaybob August 17th 2010, 3:50 pm
The mounting face should always be as close to the front main as you can get it. Unless you are forced to hang the pulley out on the end of the snout, I'd try to keep it as close as possible... Mine will be close...
Jaybob
Post  gafred99 August 17th 2010, 4:15 pm
Yes thats how I run mine invertered, I have seen one where it was the other way with a standard car snout it looked scary. When that manifold heats up it grows stretching the belt tighter somethign will let go.
You runnign alcohol or gas? pump driven of the front of the cam?
gafred99
Post  Jaybob August 17th 2010, 5:43 pm
This is a pro-streeter... The plan is to run EFI on pump gas with about 9lbs boost... I'm making my own intake... I'm probably going to modify a tunnle ram, but I may design what I want and have it cast...
Jaybob
Post  gafred99 August 21st 2010, 10:02 pm
I need a 4.15 crank for my main engine and have been considering a BBC snout for strength, more boost more load on the front drive. Probably call Adney in the Fall to see what he has.
good luck with your build and lay down as much rubber when you can Very Happy
gafred99
Post  Jaybob August 21st 2010, 10:22 pm
Thanks! Same to you!
When you do go hunting for a crank, you can't go wrong with Adney at Performance Crankshafts!
Jaybob
