Switching from dry sump to wet sump.....
DanH
I have noticed some of the local nitrous outlaw Pro Mod guys are on a weight reduction kick trying to find any way of hoping to keep up with the blower cars. One way some guys are loosing some weight is dumping their dry sump setups in favor of a wet sump & a smaller external pump. They claim the small HP gain from the dry sump isn't worth the extra weight (40 to 80 lbs is the range I hear) of the dry setup.
I had pretty much always assumed that a 700+ inch nitrous engine "needed" a dry sump setup (reliable oiling) , but I guess not.
Anyone else seeing this change? Or is this just something going on locally here?
DILLIGASDAVE- Posts : 2262
Re: Switching from dry sump to wet sump.....
only time I feel there is a need for a dry sump is oval track racing .
DanH- Posts : 1081
The prostockers seem to have drysump oiling systems. You think they use them because they have no value?DanH wrote:only time I feel there is a need for a dry sump is oval track racing .
I did use the word NEED . Pro Stocks , when 10 HP gain cost thousands of dollars, they have a need . they race pounds per cubes . all other non class cars can get by without it . like the original post said , lose of weight seems more important to some ownersLem Evans wrote:The prostockers seem to have drysump oiling systems. You think they use them because they have no value?DanH wrote:only time I feel there is a need for a dry sump is oval track racing .
DanH- Posts : 1081
good hit of NOS!it's worked for them before.Lem Evans wrote:Sounds what they 'need' is a blower
Yep, they need a blower. A bunch of billet blowers..... I'll keep my drysump.
Yeah, I dont see any down side to primo oil control. If you're gonna spend a fortune on a top notch motor, you need a top notch oiling system.
Curt- Posts : 2791
theres a lot to be said about a dry sump, and one is it will make more then 10hp,other is we run some of our bb engines above 9500 rpm,most @8000 some are at that or above for 30 plus sec 's in the cars its safer, makes more power
prostock has no choice, theres no room for a oil pan that would hold 12 plus q's of oil,when they started using them it was for power gains,now its a given
BOSS 429- Posts : 2372
» Front sump vs rear sump
» Switching
» Switching to 16 volts
» switching cabs on f-350???
» Switching fuels.
» Switching
» Switching fuels.
