Anyone want to guess what broke in tranny (c4}?
+6
Wheelie58
Ed501
10 posters
Did a big wheelstand came down kinda hard , first time having to peddle got back in second got squirally straightened it out and short shifted into 3rd firm bang then nothing in any gear, I am thinking input shaft or other hard part, should know tommarrow..., ED
Ed501- Posts : 139
My guess
Ed,
I would suspect an input shaft related problem since it has no gears....and the physical diameter if the C4 input shaft....leads me to that guess. I have a buddy that has snapped 2 with a small block.
Keith
Keith
Re: Anyone want to guess what broke in tranny (c4}?
yep input shaft.
I too would say the input shaft. I ran the C-4's with a C-6 converter and spline adapter for years, would split the adapter atleast once a year.
Travis
Travis
TravisRice- BBF CONTRIBUTOR
no more splines in forward drum
Cracked the forward drum and ripped out the splines. This was the 3rd pass , but was really first pass without ignition problem, boy it wasnt same car. I used a good early c4 drum and it was really tight 3 passes ago. Remember first two passes never got out of converter around 52-5500 rpms, i couldnt keep it under 7000 rpmsthis time and it never let the converter stall slow rpms, so it was making alot more torque and the stall speed footbrake showd it I hope a good welded one will hold this time., ED
Ed501- Posts : 139
what's the weight on your car?
around 3150 with driver
Ed501- Posts : 139
your Problem lies in the C-4 they are not very strong as everyone thinks they are....
the Coug- Posts : 3055
They will handle quite a bit, the stock drums don't last long behind torque.............
I have a friend that wants to weld drum
How hard to drill after welding? Do i nead to weld it flush requiring machining flat? Trying to decide to buy one or find one and have it done.,/,,ED
Ed501- Posts : 139
The ones I used were silicon bronzed, I think I got it from Dynamic Racing Transmission, not that expensive, hole already drilled.
Stator support will do the same thing..
Ace
Ace
powerstrokeace- Posts : 1496
need to find one just welded and drilled no thrills
Like to find one without and thrills, stock spring type not already loaded, my stuff is still new, cant find anything from dynamic, suspose to call back/.,
Ed501- Posts : 139
Jay broader performance in Texas. or try clickclick.com
Ace
Ace
Last edited by powerstrokeace on September 6th 2010, 7:54 pm; edited 1 time in total
on his answering machine also
I like the thought of brazing, my grandfather brazes everthing out at the farm= easy to drill also, wonder what brazing rod if theres a differance././., ED
Ed501- Posts : 139
fwiw... Joels On Joy in Detroit builds tons of C4's... he built the C4 thats in the Mustang "cobra jet" race car that Ford sells. Also created the C2 trans thats in them too.
I had my rollerized C6 built by him.
Shane
Shane
TorinoGT- Posts : 174
glide would be the easiest. buy one and be done.
whatbumper- Posts : 3024
buy one eeasy ??
I dont need this thing bullet proof. A few weekend a yr. on test and tune. I dont like E.T racing ,I hate loosing lol. I plan on going to cruise Inns and some car stuff, shows. It never even sees race gas. I am however looking into a glide and see if it still beable to do some cruising like the c4. The big plus is i am familar with a c4 not any other tranny. I aleast giving it one more chance ,it could of been a fluke.
Ed501- Posts : 139
whatbumper wrote:glide would be the easiest. buy one and be done.
he'[s already been beaten up about a glide enough over on the bullet......lol
One day you will realize it is the right path, make the switch, then wonder why the hell you fought the c4 for so long...............in my case the 4000 dollar C4 I had is living a long happy life behind our smallblock now.............
glides are easy. I have rebuilt them at the track for people and I am not the smartest in the world.
I loved my C4, but the maintenance gets old. maybe try a TH400 if you got your heart set on a 3 speed.
or a c6.Barney wrote:I loved my C4, but the maintenance gets old. maybe try a TH400 if you got your heart set on a 3 speed.
I dont feel bad this is the first c4 that i have ever hurt and used to spray the converter on brake. I might need to change the R servo to take away some kick in third. Still did a second gear burnout at Beechbend with the small 2nd apply. I wouldnt mind having a 400Turbo if i could work it.
Ed501- Posts : 139
» Broke tranny right before the bash
» Broke into the 8s.
» cam pin broke.....
» Well my Cam pin broke what kind should I get now??
» Broke Down and Bought Some
