What do you guys think??
Induction-Solutions
1Bad91
What do you guys think?? Empty What do you guys think??
Post  1Bad91 September 21st 2010, 10:06 pm
I have a BBF around 9:8:1 compression and looking to see what you guys think what kind of timing would need to be pulled when spraying? Also, with this compression what at the minimum on octane would you run when spraying this compression ratio? I personally feel 110 may be a bit too much, but chime in and tell me your opinions. My ears are open. I'm looking to spray around 150-225 shot.
1Bad91
1Bad91
What do you guys think?? Empty Re: What do you guys think??
Post  bruno September 21st 2010, 10:16 pm
i forgot your build ...can you please post some details
http://WWW.CKRME.COM
Post  1Bad91 September 23rd 2010, 7:20 pm
504 bbf, dished pistons, 9:8:1 comp, 1000cfm 4150, victor/C9VE heads, 240ish duration/650 lift solid roller cam
1Bad91
1Bad91
Post  Induction-Solutions September 27th 2010, 10:21 am
I don't think 110 octane is to much.. I feel octane is your friend with nitrous.. Also what plug are you going to run ?? SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  1Bad91 September 28th 2010, 7:14 pm
I run the autolight plugs
1Bad91
1Bad91
Post  bruno September 28th 2010, 7:42 pm
1Bad91 wrote:I run the autolight plugs
what heat range is what Steve means
Post  1Bad91 September 29th 2010, 10:45 pm
Heat range? You mean what exact plug I'm using? I'm confused...lol
1Bad91
1Bad91
Post  res0rli9 September 29th 2010, 10:58 pm
1Bad91 wrote:Heat range? You mean what exact plug I'm using? I'm confused...lol
Yes!! Whats the # on the plug
Post  bruno September 29th 2010, 11:08 pm
x2 yes
Post  1Bad91 September 30th 2010, 5:35 pm
AUTOLIGHT 124!!! These are about the only autolight plugs you can use on spray. Unless there is a colder plug by this brand that I dont know about that fits casts heads.
1Bad91
1Bad91
Post  Induction-Solutions October 4th 2010, 5:56 pm
The 124 is a heat range 4 plug and in my opinion is a little hot for what your wanting.. Thanks, SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  whatbumper October 4th 2010, 7:43 pm
Maybe Autolite ar33 or ar32? the 32's are the coldest of those two.
Post  Barney October 5th 2010, 10:15 am
You must have D0VE heads. I use autolite 124s in my D0VE headed combo also. There isnt alot available for that head without inserts, and thats about as cold as your going to get. I have sprayed a 110 squared with no problems with them so you should be fine.
Barney
Barney
Post  Barney October 5th 2010, 10:16 am
He cant use those without adapters.
Barney
Barney
Post  1Bad91 October 5th 2010, 10:19 am
So the 124's are the coldest plug i could use, unless I went with an adapter? What would be the advantages going with a colder plug?
1Bad91
1Bad91
Post  Barney October 5th 2010, 10:24 am
1Bad91 wrote:So the 124's are the coldest plug i could use, unless I went with an adapter? What would be the advantages going with a colder plug?
You can use the standard AR plugs I.E AR33/AR32.
Barney
Barney
Post  whatbumper October 5th 2010, 11:16 am
124
18mm Thread Size, 11.6mm (.460") Reach, 13/16" (20.6mm) Hex Size, Tapered Seat, Resistor, Copper Core, Heavy Duty Center Electrode, Solid Terminal Nut, .031" (0.8mm) Gap, Heat Range 4
AR33
18mm Thread Size, 11.6mm (.460") Reach, 13/16" (20.6mm) Hex Size, Tapered Seat, Non-Resistor, Power Tip, Copper Core, Racing Plug with Nickel Plated Shell, Solid Terminal Nut, .028" (0.7mm) Gap, Heat Range 3
AR32
18mm Thread Size, 11.6mm (.460") Reach, 13/16" (20.6mm) Hex Size, Tapered Seat, Non-Resistor, Power Tip, Copper Core, Racing Plug with Nickel Plated Shell, Solid Terminal Nut, .028" (0.7mm) Gap, Heat Range 2
I don't use any of these but why is an adaptor needed? Am I missing something here?
Post  1Bad91 October 5th 2010, 2:07 pm
I use the 124's and never knew about an adapter or those other plugs. WhatBumper, what are you confused about? I should be more confused than you....lol
1Bad91
1Bad91
Post  1Bad91 October 5th 2010, 2:10 pm
but your information above is greatly appreciated. I did not know about them plugs. SHould I be running them plugs instead of the 124's, or would it not make any difference? I'm new to this NO2 stuff and looking for all the knowledge possible. I like to know all the pros and cons because NO2 is probably what I will always be running for pwr adder. Everybody helping is awesome. Thanks a bunch. Very Happy
1Bad91
1Bad91
Post  Barney October 5th 2010, 2:15 pm
I dont know where that info came from, but I dont think those plugs will not work in your cylinder head without adapters. Autolite lists them as a 13/16hex, but I think I ordered them a long time ago for my D0VE headed motor and they were standard 5/8 hex similar to the 3932. I could be wrong though.
Barney
Barney
Post  whatbumper October 5th 2010, 4:00 pm
Barney wrote:I dont know where that info came from, but I dont think those plugs will not work in your cylinder head without adapters. Autolite lists them as a 13/16hex, but I think I ordered them a long time ago for my D0VE headed motor and they were standard 5/8 hex similar to the 3932. I could be wrong though.
that was from www.autolitesparkplugs.com website. that's why I asked what the difference was. I use and sell ngk so i am not that familiar with the autolites anymore.
Post  Barney October 5th 2010, 4:26 pm
I myself think the 124s are fine for the HP levels your spraying. Like I said earlier Ive sprayed 110 squared with 124s and D0VE heads and never had ANY issues.
Barney
Barney
Post  1Bad91 October 6th 2010, 9:50 am
when you say 110 squared your talking 55N and 55F? What kind of shot is that?
1Bad91
1Bad91
Post  whatbumper October 6th 2010, 11:08 am
1Bad91 wrote:when you say 110 squared your talking 55N and 55F? What kind of shot is that?
he probably means 110's on each.
Post  Barney October 6th 2010, 11:45 am
Its around 350HP on my car 110n/110f.
Barney
Barney
